Where I have created a use case diagram and then used VP-UML to create a sequence diagram, is it then possible to use VP-UML to automatically create either candidate classes, or better still to automatically create a class diagram containing the classes?
Thanks, Terry.
Hi Terry,
Thanks for your post. You can switch to the Model Explorer, right-click on the lifeline model and select Create Class in the popup menu, then you will be able to create the class model and class diagram with it.
BTW, from the attached flash, you will see how you can create sequence diagram from use case details and create class model from lifeline. Hope it can help answering your question. If there is any further inquiry, please feel free to ask.
[Flash]Create_UCD_then_SD_then_classes.zip
