Hi!
I am attaching this file containing the sequence diagram…My problem is I want a sequence number 4.1 instead of 6 at message "clearSelection pointing to a new Lifeline. Can anyone help.
Thanks .
got it!! It’s a simple problem…It’s just that I right clicked on the message and went to sequence numbers(last option in the pop-up menu) and then selected manual…
I am providing this info for people with this same problem…
Thanks everyone…
Thank you for your post!
I can’t find this option, can you post a screenshot or detailed advice? Thanks
Hi Wolfgang,
The tutorial below shows how you can change the sequence numbering method via the diagram’s popup menu:
Once you have selected “Manual” as the sequence numbering method, you can then open the specification of the desired message and set it to whatever value you want:
Hope this helps,
Antony.
