I am tring to import various tables and its related info to a diagram inspired by your sample Create Entity-Relationship Diagram Using Open API - Visual Paradigm Know-how
, but could not find a way to set the schema name of a IDBTable ,which is already defined in the lookup as below
The API scripts is as follows, but unfortunately , the schema of the table “tableRetailCenter” can not be set to “schema2”
//Create the table
IDBTable tableRetailCenter = IModelElementFactory.instance().createDBTable();
tableRetailCenter.setName("Retail Center");
IDBSchemaLookup sch = IModelElementFactory.instance().createDBSchemaLookup();
sch.setName("schema2");
tableRetailCenter.setSchemaLookup(sch);
I tried to get the lookup list (as in screen shot , schema,schema2,schema3 ) by using IDBLookupContainer and then set one of them to tables schema but it did not work too, because I get empty IDBSchemaLookup array “schs”.
IModelElementFactory.instance().createDBLookupContainer();
IDBLookupContainer lkp =IModelElementFactory.instance().createDBLookupContainer();
IDBSchemaLookup[] schs= lkp.toDBSchemaLookupArray();
Your advice and guidance is greatly appreciated.
November 8, 2021, 3:27am
2
Hi Seyhmus,
Thank you for your post. Your question has been forwarded to our team. When there is an answer, I will let you know.
Hi Jick,
While we get answer from you I tried further with the script below but still no luck
//Create table for retail centers
String lSpecifiedModelType_schema = IModelElementFactory.MODEL_TYPE_DB_TABLE;
IModelElement[] lschemalookups = lProject.toAllLevelModelElementArray(IModelElementFactory.MODEL_TYPE_DB_SCHEMA_LOOKUP);
if (lschemalookups != null) {
for (IModelElement lschemalookup : lschemalookups) {
ApplicationManager.instance().getViewManager().showMessage("schema:" + lschemalookup.getName() );
IDBSchemaLookup sch =(IDBSchemaLookup) lschemalookup;
if (sch.getName().equals("schema2") ){
November 15, 2021, 3:45am
5
Sorry for not getting back to you sooner. I have updated the report I sent to our team by including your latest code sample.
December 6, 2021, 10:51am
6
Hi Seyhmus,
You may try the code below:
final String tableName = "Retail Center";
final String schemaName = "schema2";
com.vp.plugin.model.IProject project = com.vp.plugin.ApplicationManager.instance().getProjectManager().getProject();
com.vp.plugin.model.IDBTable table = com.vp.plugin.model.factory.IModelElementFactory.instance().createDBTable();
table.setName(tableName);
com.vp.plugin.model.IDBLookupContainer lookupContainer = null;
Iterator lookupContainerIterator = project.modelElementIterator(com.vp.plugin.model.factory.IModelElementFactory.MODEL_TYPE_DB_LOOKUP_CONTAINER);
if (lookupContainerIterator != null && lookupContainerIterator.hasNext()) {
lookupContainer = (com.vp.plugin.model.IDBLookupContainer) lookupContainerIterator.next();
} else {
lookupContainer = com.vp.plugin.model.factory.IModelElementFactory.instance().createDBLookupContainer();
com.vp.plugin.model.IDBSchemaLookup schemalookup = (com.vp.plugin.model.IDBSchemaLookup) lookupContainer.getChildByName(com.vp.plugin.model.factory.IModelElementFactory.MODEL_TYPE_DB_SCHEMA_LOOKUP, schemaName);
if (schemalookup == null) {
schemalookup = lookupContainer.createDBSchemaLookup();
schemalookup.setName(schemaName);
table.setSchemaLookup(schemalookup);
Hello Jick
That worked . Thank you very much.
Regards
seyhmus
