in ‘Reverse Code’, what’s the difference between Source Path and Cpp Path?
You can generate implementation (.cpp) in different folder by setting cpp path.
The setting is shared between reverse code and generate code, so once you setup in either reverse code or generate code, you can generate code by popup menu without showing this dialog again.
