I’m currently evaluating Spring Framework and Hibernate as my choice of next projects.
As I read from this forum, Hibernate technology is built in in VP-DA fo OR mapping, isn’t it?
Can I integrate Spring framework with VP-UML / SDE ? Any special benefit for using Spring with these tools? Or if I should not, any kind of framework that you, other users suggest to work with Visual - Paradigm software very well.
I’m a little bit new to VP, Java framework, and UML. Just want to make sure that I can choose the right framework/design tool.
Our persistence layer is built on top of Hibernate. It adds some features for supporting advanced object to relational mapping. In addition, our code generation engine can generate Java classes and class to table mapping file based on the class diagram and entity relationship diagram.
The ORM code generated from DB-VA can integrate with the Spring Framework. However, our design tool does not generate Spring Framework code currently.
