Hey!
I am evaluating VP-UML ver. 6.0 professional and have a few questions.
The reason for my questions is that I am comparing VP-UML with Visual State 5.3 from IAR-Systems.
The questions are all about state machine diagrams.
Is it possible to specify a negative state condition?
When I generate state machine code (which is what I want from VP-UML) I cant see the underlying code. There is practically no code despite the fact that I have several diagrams with several states and many signal triggers. The only code is the “default transition” code. (and of course a lot of class definitions) Why is that?
I would like to know what happens when a trigger of a kind is being trigged. How is the state changed ( in code)?
hey!
Thanks but the tutorial video is too superficial and does not at all give an answer to my question. The video shows how to draw the model and how to generate code, but how do I use the code that has been generated??
The thing is, if I was to implement a state machine on my own I would write a function called ChangeState() that is called when a state has to change. If you have a state A and state B with a transition, A->B called eg “1”, and you are in state A you would have to call some kind of function (with “1” as your input parameter) that will start the transition and change the state from A to B.
I would like to know if there is a function like this, and where in the generated code it is.
All in all my question is how to use this state machine in my application?
Hey! thanks for the reply but I still havent got my question answered quite right.
Do you have any examples that contain both the state machine diagram, the generated code and an application that uses the generated code?
I would like to see how it is done. It doesnt need to be something fancy, a “hello world”-like project would be fine.
