Hi there,
I’ve installed teamwork server on my system which is inside of our LAN.
I’ve created 4 different user with there permissions.
But they are not able to access teamwork from there machine. Please let me know where exactly I’m missing. What more I need to configure.
Thanks for your post. Please make sure that your firewall settings are correct so that it allows access to the Teamwork Server.
Also, could you please export the complete vp.log file from the About dialog box (you may refer to the attached image) and attach here for investigation? Thanks in advance!
Just installed the server on a Linux environment and no client is able to login. Its not a firewall problem, already check it…
The clients are able to acquire license from floating license server and the user can login the web interface without problem.
