I am trying to use the class diagram to generate C# code.
The class diagram describes:
class MyClass2 implements interface IMyClass2
class MyClass implements interface IMyClass
class MyClass has a property named myTaskProp, the type of myTaskProp is Task<string>
And the generated code is strange, class MyClass2 implements interface IMyClass2<string>
When I try to generate JAVA code, the implement relation seems right.
I can only attach 1 image because [Sorry, new users can only put one embedded media item in a post.]
chou
May 14, 2021, 12:27am
2
Hi Chou,
Thank you for your post. May I collect your sample project file for checking? If you agree, please upload the following repository:
https://files2.visual-paradigm.com/index.php/s/862PWkS43HxDQLA
Password: nk0njewnjsdc67bjudf
(Only Visual Paradigm staff can access the uploaded file(s))
Look forward to hearing from you.
Hi, Jick Yeung
I’ve uploaded a project file named TestVP.vpp to the repository.
Looking forward to your reply.
chou
May 17, 2021, 3:57am
4
Hi Chou,
We have obtained the file and are now checking. Thank you. It looks like the addition of is related to MyClass and IMyClass… When I have got a reply from our engineers, I will let you know.
TestVP
May 28, 2021, 10:06am
7
Hi, Jick Yeung
Two weeks have passed, I would like to know if there is any update on this question
cgzhou
May 28, 2021, 11:33am
8
Hi cgzhou,
Thanks for your reminder. I just checked and found that the report is still pending to be reviewed. I already asked our engineers to take a look.
May 31, 2021, 11:25am
9
Hi cgzhou,
I am glad to inform you that the problem has been fixed. You can now update your installation to the latest patch build (16_3_20210540aq or higher) to obtain the fix. The article below shows you the steps in detail.
Upon receiving a problem report or request of enhancement, we do our best to make the necessary changes. You will then be suggested to update your Visual Paradigm installation to the patch release, in which the fix or enhancement has been made. In...
Est. reading time: 1 minute
TestVP
June 1, 2021, 2:23am
10
Hi, Jick Yeung
Roger that, thanks a lot.
cgzhou
