Perhaps a different cause, but I can’t start either. Program exits while initializing models. here is the log file:
An unexpected error has been detected by HotSpot Virtual Machine:
EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x7c910f29, pid=5784, tid=6048
Java VM: Java HotSpot™ Client VM (1.5.0_04-b05 mixed mode, sharing)
Problematic frame:
C [ntdll.dll+0x10f29]
--------------- T H R E A D ---------------
Current thread (0x009c1840): JavaThread “Thread-313” [_thread_in_native, id=6048]
siginfo: ExceptionCode=0xc0000005, reading address 0x00000003
Registers:
EAX=0x05570d70, EBX=0x003d0000, ECX=0x00000003, EDX=0x00000001
ESP=0x06abf5e8, EBP=0x06abf5f4, ESI=0x05570d68, EDI=0x0556d6c8
EIP=0x7c910f29, EFLAGS=0x00010246
Top of Stack: (sp=0x06abf5e8)
0x06abf5e8: 003d0000 0556fbf8 00000000 06abf6c8
0x06abf5f8: 7c910d5c 055ea548 00000003 06abf6ac
0x06abf608: 00000000 055ea548 0556fc00 77c2c21b
0x06abf618: 045c0000 009ddeb8 0556d6c8 009ddf54
0x06abf628: 7ffa6000 50ff8001 7ffa6000 009ddf74
0x06abf638: 009ddfc4 50ff8001 00010000 00000000
0x06abf648: 00000000 00010000 06abf6ac 6d259a9c
0x06abf658: 06abf66c 00000001 0556f75c 0556f730
Instructions: (pc=0x7c910f29)
0x7c910f19: 85 92 00 00 00 8b 4e 0c 8d 46 08 8b 10 89 4d 0c
0x7c910f29: 8b 09 3b 4a 04 89 55 14 0f 85 ea 0f 00 00 3b c8
Stack: [0x068c0000,0x06ac0000), sp=0x06abf5e8, free space=2045k
Native frames: (J=compiled Java code, j=interpreted, Vv=VM code, C=native code)
C [ntdll.dll+0x10d5c]
C [msvcrt.dll+0x1c2de]
Java frames: (J=compiled Java code, j=interpreted, Vv=VM code)
j sun.font.FileFont.getGlyphImage(JI)J+0
j sun.font.FileFontStrike.getGlyphImagePtr(I)J+62
j sun.font.FileFontStrike.getGlyphMetrics(I)Ljava/awt/geom/Point2D$Float;+25
j sun.font.StandardGlyphVector$GlyphStrike.addDefaultGlyphAdvance(ILjava/awt/geom/Point2D$Float;)V+5
j sun.font.StandardGlyphVector.initPositions()V+106
j sun.font.StandardGlyphVector.getLogicalBounds()Ljava/awt/geom/Rectangle2D;+5
j java.awt.Font.getStringBounds([CIILjava/awt/font/FontRenderContext;)Ljava/awt/geom/Rectangle2D;+168
j java.awt.Font.getStringBounds(Ljava/lang/String;Ljava/awt/font/FontRenderContext;)Ljava/awt/geom/Rectangle2D;+11
j java.awt.FontMetrics.getStringBounds(Ljava/lang/String;Ljava/awt/Graphics;)Ljava/awt/geom/Rectangle2D;+10
j v.bxi.i()V+56
j v.ryy.run()V+7
v ~StubRoutines::call_stub
--------------- P R O C E S S ---------------
Java Threads: ( => current thread )
0x009da830 JavaThread “Timer-336” [_thread_blocked, id=2000]
=>0x009c1840 JavaThread “Thread-313” [_thread_in_native, id=6048]
0x009d06c0 JavaThread “TimerQueue” daemon [_thread_blocked, id=5096]
0x009bea90 JavaThread “Image Fetcher 2” daemon [_thread_blocked, id=4608]
0x009be4a0 JavaThread “Image Fetcher 1” daemon [_thread_blocked, id=4596]
0x009b7330 JavaThread “Thread-5” [_thread_blocked, id=4436]
0x009ae200 JavaThread “Image Fetcher 0” daemon [_thread_blocked, id=4416]
0x009ab1e0 JavaThread “com.jniwrapper.NativeResourceCollector” daemon [_thread_blocked, id=3092]
0x0098c790 JavaThread “Thread-2” [_thread_blocked, id=6072]
0x00987ad0 JavaThread “AWT-EventQueue-0” [_thread_blocked, id=6036]
0x00986640 JavaThread “AWT-Windows” daemon [_thread_in_native, id=6016]
0x00986100 JavaThread “AWT-Shutdown” [_thread_blocked, id=6012]
0x00985500 JavaThread “Java2D Disposer” daemon [_thread_blocked, id=6008]
0x0097d310 JavaThread “Low Memory Detector” daemon [_thread_blocked, id=5860]
0x0097c7f0 JavaThread “CompilerThread0” daemon [_thread_in_vm, id=5856]
0x0097c100 JavaThread “Signal Dispatcher” daemon [_thread_blocked, id=5852]
0x0097b2d0 JavaThread “Finalizer” daemon [_thread_blocked, id=5848]
0x0097ace0 JavaThread “Reference Handler” daemon [_thread_blocked, id=5844]
0x009732e0 JavaThread “main” [_thread_blocked, id=5788]
Other Threads:
0x0097a3e0 VMThread [id=5840]
0x0097edc0 WatcherThread [id=5872]
VM state:not at safepoint (normal execution)
VM Mutex/Monitor currently owned by a thread: ([mutex/lock_event])
[0x009727d0/0x0000006c] CodeCache_lock - owner thread: 0x0097c7f0
[0x00972ec0/0x00000164] MethodCompileQueue_lock - owner thread: 0x0097c7f0
Heap
def new generation total 9152K, used 3960K [0x06b90000, 0x07570000, 0x092f0000)
eden space 8192K, 37% used [0x06b90000, 0x06e8a100, 0x07390000)
from space 960K, 95% used [0x07480000, 0x075642c8, 0x07570000)
to space 960K, 0% used [0x07390000, 0x07390000, 0x07480000)
tenured generation total 121024K, used 9696K [0x092f0000, 0x10920000, 0x26b90000)
the space 121024K, 8% used [0x092f0000, 0x09c681b8, 0x09c68200, 0x10920000)
compacting perm gen total 13312K, used 13228K [0x26b90000, 0x27890000, 0x2ab90000)
the space 13312K, 99% used [0x26b90000, 0x2787b1c8, 0x2787b200, 0x27890000)
ro space 8192K, 62% used [0x2ab90000, 0x2b0993f0, 0x2b099400, 0x2b390000)
rw space 12288K, 46% used [0x2b390000, 0x2b91fe20, 0x2b920000, 0x2bf90000)
Dynamic libraries:
0x00400000 - 0x00432000 C:\Program Files\VP Suite 2.0\launcher\run_vpuml.exe
0x7c900000 - 0x7c9b0000 C:\WINDOWS\system32\ntdll.dll
0x7c800000 - 0x7c8f4000 C:\WINDOWS\system32\kernel32.dll
0x77dd0000 - 0x77e6b000 C:\WINDOWS\system32\ADVAPI32.DLL
0x77e70000 - 0x77f01000 C:\WINDOWS\system32\RPCRT4.dll
0x77f10000 - 0x77f56000 C:\WINDOWS\system32\GDI32.dll
0x77d40000 - 0x77dd0000 C:\WINDOWS\system32\USER32.dll
0x77c10000 - 0x77c68000 C:\WINDOWS\system32\msvcrt.dll
0x7c9c0000 - 0x7d1d4000 C:\WINDOWS\system32\SHELL32.DLL
0x77f60000 - 0x77fd6000 C:\WINDOWS\system32\SHLWAPI.dll
0x76390000 - 0x763ad000 C:\WINDOWS\system32\IMM32.DLL
0x629c0000 - 0x629c9000 C:\WINDOWS\system32\LPK.DLL
0x74d90000 - 0x74dfb000 C:\WINDOWS\system32\USP10.dll
0x773d0000 - 0x774d2000 C:\WINDOWS\WinSxS\x86_Microsoft.Windows.Common-Controls_6595b64144ccf1df_6.0.2600.2180_x-ww_a84f1ff9\comctl32.dll
0x5d090000 - 0x5d127000 C:\WINDOWS\system32\comctl32.dll
0x6d640000 - 0x6d7c9000 c:\progra~1\vpsuit~1.0\jre\bin\client\jvm.dll
0x76b40000 - 0x76b6d000 C:\WINDOWS\system32\WINMM.dll
0x6d280000 - 0x6d288000 c:\progra~1\vpsuit~1.0\jre\bin\hpi.dll
0x76bf0000 - 0x76bfb000 C:\WINDOWS\system32\PSAPI.DLL
0x6d610000 - 0x6d61c000 c:\progra~1\vpsuit~1.0\jre\bin\verify.dll
0x6d300000 - 0x6d31d000 c:\progra~1\vpsuit~1.0\jre\bin\java.dll
0x6d630000 - 0x6d63f000 c:\progra~1\vpsuit~1.0\jre\bin\zip.dll
0x6d000000 - 0x6d167000 C:\Program Files\VP Suite 2.0\jre\bin\awt.dll
0x73000000 - 0x73026000 C:\WINDOWS\system32\WINSPOOL.DRV
0x774e0000 - 0x7761d000 C:\WINDOWS\system32\ole32.dll
0x5ad70000 - 0x5ada8000 C:\WINDOWS\system32\uxtheme.dll
0x6d240000 - 0x6d27d000 C:\Program Files\VP Suite 2.0\jre\bin\fontmanager.dll
0x74720000 - 0x7476b000 C:\WINDOWS\system32\MSCTF.dll
0x755c0000 - 0x755ee000 C:\WINDOWS\system32\msctfime.ime
0x6d3c0000 - 0x6d3df000 C:\Program Files\VP Suite 2.0\jre\bin\jpeg.dll
0x6d190000 - 0x6d1bf000 C:\Program Files\VP Suite 2.0\jre\bin\cmm.dll
0x6d4c0000 - 0x6d4d3000 C:\Program Files\VP Suite 2.0\jre\bin\net.dll
0x71ab0000 - 0x71ac7000 C:\WINDOWS\system32\WS2_32.dll
0x71aa0000 - 0x71aa8000 C:\WINDOWS\system32\WS2HELP.dll
0x6d4e0000 - 0x6d4e9000 C:\Program Files\VP Suite 2.0\jre\bin\nio.dll
0x5b860000 - 0x5b8b4000 C:\WINDOWS\system32\netapi32.dll
0x01570000 - 0x01575000 C:\Program Files\VP Suite 2.0\bin\vp_windows\E1.dll
0x76b20000 - 0x76b31000 C:\WINDOWS\system32\ATL.DLL
0x77120000 - 0x771ac000 C:\WINDOWS\system32\OLEAUT32.dll
0x01580000 - 0x01585000 C:\Program Files\VP Suite 2.0\bin\vp_windows\I1.dll
0x01590000 - 0x01595000 C:\Program Files\VP Suite 2.0\bin\vp_windows\W1.dll
0x71a50000 - 0x71a8f000 C:\WINDOWS\System32\mswsock.dll
0x76f20000 - 0x76f47000 C:\WINDOWS\system32\DNSAPI.dll
0x76fb0000 - 0x76fb8000 C:\WINDOWS\System32\winrnr.dll
0x76f60000 - 0x76f8c000 C:\WINDOWS\system32\WLDAP32.dll
0x751d0000 - 0x751ee000 C:\WINDOWS\system32\wshbth.dll
0x77920000 - 0x77a13000 C:\WINDOWS\system32\SETUPAPI.dll
0x76fc0000 - 0x76fc6000 C:\WINDOWS\system32\rasadhlp.dll
0x05210000 - 0x0521a000 C:\Program Files\VP Suite 2.0\bin\vp_windows\jniwrap.dll
0x763b0000 - 0x763f9000 C:\WINDOWS\system32\COMDLG32.DLL
0x76840000 - 0x76873000 C:\WINDOWS\System32\spool\DRIVERS\W32X86\3\UNIDRVUI.DLL
0x778d0000 - 0x77913000 C:\WINDOWS\System32\spool\DRIVERS\W32X86\3\UNIDRV.DLL
0x05240000 - 0x052e7000 C:\WINDOWS\System32\spool\DRIVERS\W32X86\3\pcl5eres.dll
0x68280000 - 0x682a3000 C:\WINDOWS\System32\spool\DRIVERS\W32X86\3\hpcfont.dll
VM Arguments:
jvm_args: -Dexe4j.isInstall4j=true -Dexe4j.moduleName=c:\progra~1\vpsuit~1.0\launcher\run_vp~1.exe -Dexe4j.processCommFile=C:\DOCUME~1\SIMON~1.BLA\LOCALS~1\Temp\e4j_p5784.tmp -Dexe4j.tempDir= -Xmx512m -Xms128m -Dsun.java2d.noddraw=true
java_command:
Environment Variables:
PATH=C:\Program Files\Microsoft SQL Server\90\Tools\Binn\VSShell\Common7\IDE;C:\Program Files\Microsoft SQL Server\90\DTS\Binn;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\Program Files\ATI Technologies\ATI Control Panel;C:\Program Files\Microsoft Office\OFFICE11\Business Contact Manager\IM;C:\Program Files\Microsoft SQL Server\80\Tools\Binn;C:\Program Files\Microsoft Office\OFFICE11\Business Contact Manager;c:\Program Files\Microsoft SQL Server\90\Tools\binn
USERNAME=simon.blackwell
OS=Windows_NT
PROCESSOR_IDENTIFIER=x86 Family 15 Model 4 Stepping 1, GenuineIntel
--------------- S Y S T E M ---------------
OS: Windows XP Build 2600 Service Pack 2
CPU:total 2 family 15, cmov, cx8, fxsr, mmx, sse, sse2, ht
Memory: 4k page, physical 916460k(299312k free), swap 2221452k(1550728k free)
vm_info: Java HotSpot™ Client VM (1.5.0_04-b05) for windows-x86, built on Jun 3 2005 02:10:41 by “java_re” with MS VC++ 6.0
