I have a database model stored inside DB Visual Architect Java Edition. I am trying to use the Tools…ORM…Generate Database menu item with the following options:
Generate: Database Only
Deploy To: Standalone Application
Generate DDL checked
Export to Database unchecked
Column Order: Normal
Connection: JDBC
When I click “Test Connection”, the message says “Connect successful.” However, when I run the database code generation, I receive the following error message:
“The name of foreign key “fk_name” is duplicated.”
I was adding a new table to my schema which has foreign key relationships to existing tables. After the error message started appearing, I manually added my new table (by using generate SQL after right-clicking on my object in Visual Paradign) but this did not solve the foreign key problem.
Do you have any suggestions about what might be causing the problem?
