i’m experiencing some trouble with the new SP2 that was not present before :
- Select in Tree on a diagram doesn’t work anymore (on element still working)
- Adding parameters to a newly created operation on a Class doesn’t work (we can fill all, but it is not saved on the operation).
Arnaud
HI Arnaud,
Thanks for your post. About Select in Tree function, I’ve forwarded to our engineers to follow-up, and will keep you informed for any feedback on this issue.
About adding parameters to operation but cannot save it, this should be fixed before. Could you please download the latest patch from the following link to see whether your problem can be solved?
http://files2.visual-paradigm.com/200903/Patch/sp2_20090312p/VP_Suite_Windows_3_4_sp2_20090312p.exe
thanks i will try and inform you asap.
Another point (but i don’t remenber if it is new, volounteer or not), when i add a diagram to a package all the element of the package are expanded. It could be fine with a little package but with a big one it can be annoying to have all the element expanded.
Hi Arnaud,
For your point on package expanded when add diagram to it, I’ve forwarded to our engineers to follow-up.
no more trouble when adding an operation to a class.
Thanks a lot.
Hi Arnaud,
Good to hear that the patch solved adding operation problem. About the other 2 problems - Select in Tree not work and package expand of add sub-diagram to it, we fixed both and please find the patch below.
http://files2.visual-paradigm.com/200903/Patch/sp2_20090312r/VP_Suite_Windows_3_4_sp2_20090312r.exe
i’ll take a look as soon as possible
thanks a lot
Arnaud
Hi Arnaud,
You are welcome.
