Bug 1:
Right after installing I created a new use case diagram, added a system with an actor and one use case. I right clicked the use case and selected “Open specification”. The specification box doesn’t come up. I tried several things, closing and starting again, reinstalling, but whatever I try it won’t come up.
Bug 2:
When attempting to uninstall the product (to reinstall for the above bug) I got a very nasty error right away. It removed the product from the list of installed applications but the files and everything else are still there. On my desktop there was an error log with the following information:
at java.awt.Dimension.(Unknown Source)
at javax.swing.plaf.basic.BasicProgressBarUI.getPreferredSize(Unknown Source)
at javax.swing.JComponent.getPreferredSize(Unknown Source)
at java.awt.GridBagLayout.GetLayoutInfo(Unknown Source)
at java.awt.GridBagLayout.getLayoutInfo(Unknown Source)
at java.awt.GridBagLayout.preferredLayoutSize(Unknown Source)
at java.awt.Container.preferredSize(Unknown Source)
at java.awt.Container.getPreferredSize(Unknown Source)
at java.awt.GridBagLayout.ArrangeGrid(Unknown Source)
at java.awt.GridBagLayout.arrangeGrid(Unknown Source)
at java.awt.GridBagLayout.layoutContainer(Unknown Source)
at java.awt.Container.layout(Unknown Source)
at java.awt.Container.doLayout(Unknown Source)
at java.awt.Container.validateTree(Unknown Source)
at java.awt.Container.validate(Unknown Source)
at com.install4j.runtime.installer.frontend.BaseScreen$1.componentResized(Unknown Source)
at java.awt.AWTEventMulticaster.componentResized(Unknown Source)
at java.awt.Component.processComponentEvent(Unknown Source)
at java.awt.Component.processEvent(Unknown Source)
at java.awt.Container.processEvent(Unknown Source)
at java.awt.Component.dispatchEventImpl(Unknown Source)
at java.awt.Container.dispatchEventImpl(Unknown Source)
at java.awt.Component.dispatchEvent(Unknown Source)
at java.awt.EventQueue.dispatchEvent(Unknown Source)
at java.awt.EventDispatchThread.pumpOneEventForHierarchy(Unknown Source)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(Unknown Source)
at java.awt.EventDispatchThread.pumpEvents(Unknown Source)
at java.awt.EventDispatchThread.run(Unknown Source)
Possible glitch:
When I reinstalled the product and pointed at the key I got it worked fine. When I tried to run the program however it told me there was an invalid key code. I set it to community edition, which solved this problem.
All in all I must say the program sounds and looks good, but so far I’ve spent 3 hours of my boss’ time evaluating it with a very, very poor result.
