Which dumped alot of files into a directory i specified. I then executed
C:\I1083316273\Windows\vpumlce_20030207.exe
The installer completed with errors and suggested i look in the log file for these errors. Unfortunately I don’t know where the installer placed the log file. However, the installer did create the icons on my start menu and I tried executing “C:\Program Files\Visual Paradigm\Visual Paradigm for UML Community Edition 3.1\Visual Paradigm for UML Community Edition 3.1.exe”
But get the following error:
java.lang.ClassNotFoundException: RV
at java.net.URLClassLoader$1.run(Unknown Source)
at java.net.URLClassLoader.findClass(Unknown Source)
at java.lang.ClassLoader.loadClass(Unknown Source)
at sun.misc.Launcher$AppClassLoader.loadClass(Unknown Source)
at java.lang.ClassLoader.loadClassInternal(Unknown Source)
at java.lang.Class.forName0(Native Method)
at java.lang.Class.forName(Unknown Source)
at com.zerog.lax.LAX.launch(DashoA8113)
at com.zerog.lax.LAX.main(DashoA8113)
Any ideas. I’m really keen on trying out this software - please help.
Please try to install VP-UML CE using the NoInstall zip file (you can find this option in the download page), just extract the zip file and then execute “Visual Paradigm for UML.exe”.
Let me know you with full message text:
"Unable to Lounch Java Application"
Unable to locate the application’s ‘main’ class. The class ‘sderunner.SDERunner’ must be public and have a ‘public static void main(String[])’ method.(LAX)
Details:…
java.lang.UnsupportedClassVersionError: s/am (Unsupported major.minor version 48.0)
at java.lang.ClassLoader.defineClass0(Native Method)
at java.lang.ClassLoader.defineClass(ClassLoader.java:493)
at java.security.SecureClassLoader.defineClass(SecureClassLoader.java:111)
at java.net.URLClassLoader.defineClass(URLClassLoader.java:248)
at java.net.URLClassLoader.access$100(URLClassLoader.java:56)
at java.net.URLClassLoader$1.run(URLClassLoader.java:195)
at java.net.URLClassLoader.findClass(URLClassLoader.java:188)
at java.lang.ClassLoader.loadClass(ClassLoader.java:299)
at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:286)
at java.lang.ClassLoader.loadClass(ClassLoader.java:255)
at java.lang.ClassLoader.loadClassInternal(ClassLoader.java:315)
at java.lang.Class.forName(Class.java:120)
The file that you have downloaded (sdecejb_20040610.exe) is the SDE for JBuilder Community Edition. There is no Visual Paradigm for UML.exe. You run JBuilder first then invoke the SDE from JBuilder.
If this is not what you were looking for, you can still download the standalone Visual Paradigm for UML from our download page.
I downloaded community edition “sdecejb_20040610.exe” and install it without errors. After start same massage appears “Unable to lounch java application” . After that i download NoInstall file, but I cudn’t find file “Visual Paradigm for UML.exe”. There is VPUML.exe file, but it cann’t be started.
