Hi.
I just tried to update our VP server from 16.0. to 16.1 via web app. As the server did not respond in a while I restarted it and got the message that the server had an internal data storage failure. I was asked to submit the vpserver log which I just post at the end of this message.
I then downloaded the VP server 16.1 installed it from scratch and tried to migrate from my old server using migrate.bat. This generated the following errors:
WARNING: An illegal reflective access operation has occurred
WARNING: Illegal reflective access by org.dom4j.io.SAXContentHandler (file:/C:/VisualParadigmTeamworkServer/webserver/webapps/ROOT/WEB-INF/lib/orm.jar) to method com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser$LocatorProxy.getEncoding()
WARNING: Please consider reporting this to the maintainers of org.dom4j.io.SAXContentHandler
WARNING: Use --illegal-access=warn to enable warnings of further illegal reflective access operations
WARNING: All illegal access operations will be denied in a future release
Loading class com.mysql.jdbc.Driver'. This is deprecated. The new driver class is com.mysql.cj.jdbc.Driver’. The driver is automatically registered via the SPI and manual loading of the driver class is generally unnecessary.
10:07:16,462 WARN BasicResourcePool:1851 - com.mchange.v2.resourcepool.BasicResourcePool$ScatteredAcquireTask@18f72928 – Acquisition Attempt Failed!!! Clearing pending acquires. While trying to acquire a needed new resource, we failed to succeed more than the maximum number of allowed acquisition attempts (30). Last acquisition attempt exception:
java.sql.SQLException: The server time zone value ‘Mitteleurop?ische Zeit’ is unrecognized or represents more than one time zone. You must configure either the server or JDBC driver (via the serverTimezone configuration property) to use a more specifc time zone value if you want to utilize time zone support.
at com.mysql.cj.jdbc.exceptions.SQLError.createSQLException(SQLError.java:129)
at com.mysql.cj.jdbc.exceptions.SQLError.createSQLException(SQLError.java:97)
at com.mysql.cj.jdbc.exceptions.SQLError.createSQLException(SQLError.java:89)
at com.mysql.cj.jdbc.exceptions.SQLError.createSQLException(SQLError.java:63)
at com.mysql.cj.jdbc.exceptions.SQLError.createSQLException(SQLError.java:73)
at com.mysql.cj.jdbc.exceptions.SQLExceptionsMapping.translateException(SQLExceptionsMapping.java:76)
at com.mysql.cj.jdbc.ConnectionImpl.createNewIO(ConnectionImpl.java:836)
at com.mysql.cj.jdbc.ConnectionImpl.(ConnectionImpl.java:456)
at com.mysql.cj.jdbc.ConnectionImpl.getInstance(ConnectionImpl.java:246)
at com.mysql.cj.jdbc.NonRegisteringDriver.connect(NonRegisteringDriver.java:199)
at com.mchange.v2.c3p0.DriverManagerDataSource.getConnection(DriverManagerDataSource.java:146)
at com.mchange.v2.c3p0.WrapperConnectionPoolDataSource.getPooledConnection(WrapperConnectionPoolDataSource.java:195)
at com.mchange.v2.c3p0.WrapperConnectionPoolDataSource.getPooledConnection(WrapperConnectionPoolDataSource.java:184)
at com.mchange.v2.c3p0.impl.C3P0PooledConnectionPool$1PooledConnectionResourcePoolManager.acquireResource(C3P0PooledConnectionPool.java:200)
at com.mchange.v2.resourcepool.BasicResourcePool.doAcquire(BasicResourcePool.java:1086)
at com.mchange.v2.resourcepool.BasicResourcePool.doAcquireAndDecrementPendingAcquiresWithinLockOnSuccess(BasicResourcePool.java:1073)
at com.mchange.v2.resourcepool.BasicResourcePool.access$800(BasicResourcePool.java:44)
at com.mchange.v2.resourcepool.BasicResourcePool$ScatteredAcquireTask.run(BasicResourcePool.java:1810)
at com.mchange.v2.async.ThreadPoolAsynchronousRunner$PoolThread.run(ThreadPoolAsynchronousRunner.java:648)
Caused by: com.mysql.cj.exceptions.InvalidConnectionAttributeException: The server time zone value ‘Mitteleurop?ische Zeit’ is unrecognized or represents more than one time zone. You must configure either the server or JDBC driver (via the serverTimezone configuration property) to use a more specifc time zone value if you want to utilize time zone support.
at jdk.internal.reflect.GeneratedConstructorAccessor11.newInstance(Unknown Source)
at java.base/jdk.internal.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45)
at java.base/java.lang.reflect.Constructor.newInstance(Constructor.java:490)
at com.mysql.cj.exceptions.ExceptionFactory.createException(ExceptionFactory.java:61)
at com.mysql.cj.exceptions.ExceptionFactory.createException(ExceptionFactory.java:85)
at com.mysql.cj.util.TimeUtil.getCanonicalTimezone(TimeUtil.java:132)
at com.mysql.cj.protocol.a.NativeProtocol.configureTimezone(NativeProtocol.java:2121)
at com.mysql.cj.protocol.a.NativeProtocol.initServerSession(NativeProtocol.java:2145)
at com.mysql.cj.jdbc.ConnectionImpl.initializePropsFromServer(ConnectionImpl.java:1310)
at com.mysql.cj.jdbc.ConnectionImpl.connectOneTryOnly(ConnectionImpl.java:967)
at com.mysql.cj.jdbc.ConnectionImpl.createNewIO(ConnectionImpl.java:826)
… 12 more
10:07:16,477 WARN BasicResourcePool:894 - Having failed to acquire a resource, com.mchange.v2.resourcepool.BasicResourcePool@2a39fe6a is interrupting all Threads waiting on a resource to check out. Will try again in response to new client requests.
10:07:16,493 WARN BasicResourcePool:1851 - com.mchange.v2.resourcepool.BasicResourcePool$ScatteredAcquireTask@6fc04994 – Acquisition Attempt Failed!!! Clearing pending acquires. While trying to acquire a needed new resource, we failed to succeed more than the maximum number of allowed acquisition attempts (30). Last acquisition attempt exception:
… 12 more
10:07:16,493 WARN BasicResourcePool:894 - Having failed to acquire a resource, com.mchange.v2.resourcepool.BasicResourcePool@2a39fe6a is interrupting all Threads waiting on a resource to check out. Will try again in response to new client requests.
10:07:16,493 WARN JdbcEnvironmentInitiator:132 - HHH000342: Could not obtain connection to query metadata : Connections could not be acquired from the underlying database!
10:07:50,135 WARN BasicResourcePool:1851 - com.mchange.v2.resourcepool.BasicResourcePool$ScatteredAcquireTask@4aed3547 – Acquisition Attempt Failed!!! Clearing pending acquires. While trying to acquire a needed new resource, we failed to succeed more than the maximum number of allowed acquisition attempts (30). Last acquisition attempt exception:
… 12 more
10:07:50,135 WARN BasicResourcePool:894 - Having failed to acquire a resource, com.mchange.v2.resourcepool.BasicResourcePool@2a39fe6a is interrupting all Threads waiting on a resource to check out. Will try again in response to new client requests.
10:07:50,151 WARN SqlExceptionHelper:129 - SQL Error: 0, SQLState: null
10:07:50,151 ERROR SqlExceptionHelper:131 - Connections could not be acquired from the underlying database!
Exception in thread “main” java.lang.NullPointerException
at migration.ExportVPServerMain.a(:333)
at migration.ExportVPServerMain.(:176)
at migration.ExportVPServerMain.main(:28)
So I skipped migration but moved a backup from yesterday (made with VP 16) to the root/web-inf directory and started VP 16.1
I then got the following message:
vpserver_data.zip found. Unfortunately, its version is older than this server. Migration is suspended.
Okay, I downloaded VP Server 16.0 and the same message came up.
To test I also downloaded VP Server 15.2 and here, the server told me, that my backup is newer than the server version.
How can I now get my backup up and running?
Please help!
Regards,
Steve
VP Server log (extracts, if not enough, I can provide more):
[2020/01/20 08:48:47] [message] SLF4J: Class path contains multiple SLF4J bindings.
[2020/01/20 08:48:47] [message] SLF4J: Found binding in [jar:file:/C:/VisualParadigmTeamworkServer/webserver/webapps/ROOT/WEB-INF/lib/orm.jar!/org/slf4j/impl/StaticLoggerBinder.class]
[2020/01/20 08:48:47] [message] SLF4J: Found binding in [jar:file:/C:/VisualParadigmTeamworkServer/webserver/webapps/ROOT/WEB-INF/lib/slf4j-nop-1.7.5.jar!/org/slf4j/impl/StaticLoggerBinder.class]
[2020/01/20 08:48:47] [message] SLF4J: See http://www.slf4j.org/codes.html#multiple_bindings for an explanation.
[2020/01/20 08:48:47] [message] SLF4J: Actual binding is of type [org.slf4j.impl.Log4jLoggerFactory]
[2020/01/20 08:48:48] [message] log4j:WARN No appenders could be found for logger (org.opensaml.core.config.InitializationService).
[2020/01/20 08:48:48] [message] log4j:WARN Please initialize the log4j system properly.
[2020/01/20 08:48:48] [message] log4j:WARN See http://logging.apache.org/log4j/1.2/faq.html#noconfig for more info.
[2020/01/20 08:48:53] [error] org.orm.PersistentException: org.hibernate.exception.GenericJDBCException: Unable to acquire JDBC Connection
at org.orm.PersistentSession.doReturningWork(PersistentSession.java:795)
at v.so.dv.b(:704)
at v.so.dv.a(:452)
at v.sj.cz.init(:62)
at org.apache.catalina.core.StandardWrapper.initServlet(StandardWrapper.java:1231)
at org.apache.catalina.core.StandardWrapper.loadServlet(StandardWrapper.java:1144)
at org.apache.catalina.core.StandardWrapper.load(StandardWrapper.java:1031)
at org.apache.catalina.core.StandardContext.loadOnStartup(StandardContext.java:4914)
at org.apache.catalina.core.StandardContext.startInternal(StandardContext.java:5201)
at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:150)
at org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase.java:725)
at org.apache.catalina.core.ContainerBase.addChild(ContainerBase.java:701)
at org.apache.catalina.core.StandardHost.addChild(StandardHost.java:717)
at org.apache.catalina.startup.HostConfig.deployDirectory(HostConfig.java:1101)
at org.apache.catalina.startup.HostConfig$DeployDirectory.run(HostConfig.java:1786)
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511)
at java.util.concurrent.FutureTask.run(FutureTask.java:266)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
at java.lang.Thread.run(Thread.java:745)
Caused by: org.hibernate.exception.GenericJDBCException: Unable to acquire JDBC Connection
at org.hibernate.exception.internal.StandardSQLExceptionConverter.convert(StandardSQLExceptionConverter.java:47)
at org.hibernate.engine.jdbc.spi.SqlExceptionHelper.convert(SqlExceptionHelper.java:111)
at org.hibernate.engine.jdbc.spi.SqlExceptionHelper.convert(SqlExceptionHelper.java:97)
at org.hibernate.resource.jdbc.internal.LogicalConnectionManagedImpl.acquireConnectionIfNeeded(LogicalConnectionManagedImpl.java:87)
at org.hibernate.resource.jdbc.internal.LogicalConnectionManagedImpl.getPhysicalConnection(LogicalConnectionManagedImpl.java:109)
at org.hibernate.engine.jdbc.internal.JdbcCoordinatorImpl.coordinateWork(JdbcCoordinatorImpl.java:336)
at org.hibernate.internal.SessionImpl.doWork(SessionImpl.java:2170)
at org.hibernate.internal.SessionImpl.doReturningWork(SessionImpl.java:2166)
at org.orm.PersistentSession.doReturningWork(PersistentSession.java:793)
… 19 more
Caused by: java.sql.SQLException: Connections could not be acquired from the underlying database!
at com.mchange.v2.sql.SqlUtils.toSQLException(SqlUtils.java:118)
at com.mchange.v2.c3p0.impl.C3P0PooledConnectionPool.checkoutPooledConnection(C3P0PooledConnectionPool.java:689)
at com.mchange.v2.c3p0.impl.AbstractPoolBackedDataSource.getConnection(AbstractPoolBackedDataSource.java:140)
at org.hibernate.c3p0.internal.C3P0ConnectionProvider.getConnection(C3P0ConnectionProvider.java:73)
at org.hibernate.internal.AbstractSessionImpl$NonContextualJdbcConnectionAccess.obtainConnection(AbstractSessionImpl.java:386)
at org.hibernate.resource.jdbc.internal.LogicalConnectionManagedImpl.acquireConnectionIfNeeded(LogicalConnectionManagedImpl.java:84)
… 24 more
Caused by: com.mchange.v2.resourcepool.CannotAcquireResourceException: A ResourcePool could not acquire a resource from its primary factory or source.
at com.mchange.v2.resourcepool.BasicResourcePool.awaitAvailable(BasicResourcePool.java:1418)
at com.mchange.v2.resourcepool.BasicResourcePool.prelimCheckoutResource(BasicResourcePool.java:606)
at com.mchange.v2.resourcepool.BasicResourcePool.checkoutResource(BasicResourcePool.java:526)
at com.mchange.v2.c3p0.impl.C3P0PooledConnectionPool.checkoutAndMarkConnectionInUse(C3P0PooledConnectionPool.java:755)
at com.mchange.v2.c3p0.impl.C3P0PooledConnectionPool.checkoutPooledConnection(C3P0PooledConnectionPool.java:682)
… 28 more
[2020/01/20 08:48:53] [error] Unable to identify your database version.
[2020/01/20 08:48:53] [warning] java.lang.Exception: Cannot update database
at v.sj.cz.init(:63)
[2020/01/20 08:49:07] [error] java.lang.NullPointerException
at v.boj.g.a(:385)
at v.btq.ap.a(:31)
at v.cem.d.doGet(:53)
at v.cem.d.doGet(:36)
at v.sj.ch.doGet(:282)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:622)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:729)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:291)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
at org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:52)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:239)
at org.apache.catalina.filters.ExpiresFilter.doFilter(ExpiresFilter.java:1201)
at com.vp.vpserver.server.model.VPServerDesignFilter.doFilter(:160)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:219)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:106)
at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:502)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:142)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:79)
at org.apache.catalina.valves.AbstractAccessLogValve.invoke(AbstractAccessLogValve.java:617)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:88)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:518)
at org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:1091)
at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:668)
at org.apache.tomcat.util.net.AprEndpoint$SocketProcessor.doRun(AprEndpoint.java:2503)
at org.apache.tomcat.util.net.AprEndpoint$SocketProcessor.run(AprEndpoint.java:2492)
at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61)
[2020/01/20 08:49:26] [message] ========== UpdateProjectHandler ==================
[2020/01/20 08:49:26] [error] java.lang.NullPointerException
at v.boj.g.a(:385)
at v.btq.cu.a(:35)
at v.cem.d.doPost(:116)
at v.cem.d.doPost(:41)
at v.sj.ch.doPost(:292)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:648)
at v.boj.g.a(:385)
at v.btq.bp.a(:24)
at
