I am using SDE-VS 3.3SP2 with VS2005 VB. There are two files associated with a Windows.Forms.Form, Form1.vb and Form1.Designer.vb. The later is generated by the IDE and is a partial class. Generally the programmer works in Form1.vb, not Form1.Designer.vb. When updating the source code with changes of either an attribute or operation, SDE-VS pushes the changes to Form1.Designer.vb, not Form1.vb. Is this by design or is it incorrect? In addition only changes in Form1.Designer.vb are updated into the model.
Hi hallidd,
Thank you for your post. I just reported this problem to our developers. I will post here when it is fixed.
Have a nice weekend!
Hi hallidd,
The reported problem is fixed. Please download the hotfix at:
http://files4.visual-paradigm.com/200609/HotFix/sp2_20060922q/vpplatform.jar
The following page shows you how to install the hotfix to your current release:
http://resource.visual-paradigm.com/tips_and_tricks/general/replacing_hot_fix.html
Once again, thanks for your bug report. I will post again when a complete release is ready.
Please feel free to let me know if there are any questions about the fix.
Hello hallidd,
How are you? I am writing to inform you that we have recently released a complete release, namely 5-3-2_sp2_20061004. Since you were asked by me to use a hotfix, I would like to suggest you perform a product update to advance to the newest release. To update, please run the udpater inside $vp-suite-install-dir/bin
If there are any questions when using the newest release, please feel free to let me know.
