I work under Windows 10, and my version of VP is the 16.1 (build 20200609)
I imported a Dash Line settings exported from a Mac version (same version and same build).
But on my version the button ‘Use Case List’ remains disabled. I also don’t see it in ‘Menu/Modeling/Use Case List’ while in Customize UI it is in the Show column.
Can you explain to me what to do? Is this normal?
Thank you for your post. The Use Case List (along with some other lists) is a deprecated feature. It is no longer maintained, but if you want to use it, you can enable it in the Application Options window (Window > Application Options). Here is a screenshot for you as reference:
Thanks for your help!
It is a pity that the various lists are no longer maintained. It’s really usefull during work on a project.
I hope they won’t be removed completely in a future major release.
I take this opportunity to congratulate you for the quality and the functionalities of Visual Paradigm! I have been using it for a short time and have found it to be quite intuitive and packed with a lot of features.
