I am reading a book which pertains to .Net using UML whose author uses classes (domain objects) in Use Case Diagrams. As far as I can tell, in VP-UML, I can either have a Use Case Diagram or a Class Diagram and I can’t mix the graphics in both. Is there a way to do this???
Thanks,
Phil
Hi Phil,
Thanks for your post. You can right-click on the diagram palette and select Category > Class from the popup menu (as attached image), then you will find the category at the bottom of the diagram palette and you can create class models on use case diagram.
Lillian,
Many thanks. This is perfect for my use.
Phil
Hi Phil,
It’s my pleasure.
