the teamwork server documentation tells me that it is not recommeded to use embedded database in production because of limitations.
Can you tell me what are the limitations ?
We have only around 8-10 users ( max 8 parallel ) does the statement below from the documentation also holds for such a small production environment ?
Kind Regards
Martin
Note extracted from documentation
If you do not have a database available and if you just want to run Teamwork Server for evaluation, you may select Embedded DB as
database, which is a ready-to-use database managemnet system built into the server. In other words, no additional database setup
has to be made by choosing Embedded DB. However, it is NOT recommended to use Embedded DB for production purpose due to its
genuine limitations.
