I want to design a UI interface with Tabs. I have around 10 tabs and different field layouts and design on each of the tabs.
How do i represent the field layout and UI design in each of the tabs ? I know there is Selected tab drop-down in Specification but the text i put in any of the tabs is visible on all the tabs.
Hi askmahesh,
Currently, we support only specifying a name for a tab. Could you describe more about your layouts and designs of the tabs?
I do not quite understand the second problem you described. What do you mean by “the text i put in any of the tabs is visible on all the tabs.”? By giving a name to a tab, that name will appear only to that tab but not the others. Could you provide some screenshots to show the problem?
