i have visual errors in my vp suite 4.1 community edition.
after i start VP and then open or change to another programm / folder and then change back to VP then i only see a gray background.
when i go with the mouse over the buttons they appear suddenly.
see it on this image or attachement
http://willipfeifer.wi.funpic.de/!IMG/vpUML_Error.jpg
has anybody same errors??
Hi user,
Thank you for your post and we are sorry about the problem. Would you mind to send me the vp.log file to take a look? Thanks in advance!
call me Willy instead of User or something like that
i forgot to put my name down…
i put the vp.log as an attachement because it’s too long to post it…
by the way, i guess that the problem could be in java… or what do you think???
thanks for help
vp.log
Hi Willy,
Thanks for replying and the vp.log file. Could you please try to use JRE 1.6 and see if the problem persists? You can change to use JRE 1.6 by the steps below:
- shutdown VP-UML
- rename the “jre” folder inside VP Suite installation folder into something else
- download latest JRE 1.6 from http://java.sun.com and install it (if you have JRE 1.6 installed in your system, please skip this step)
- copy the jre folder from installed JRE 1.6 and put it into the VP Suite installation folder, make sure it’s named as “jre”
- restart VP-UML
Look forward to hearing your response.
:!: THANK YOU VERY MUCH :!:
VP-UML had Java version 5.
I’ve updated it with Java version 6 and IT WORKS NOW!!!
Thanks for the birthday present. Yes, it is today
good help here. good bye
Hi Willy,
You are welcome. Happy Birthday!!!
