Build 20210116
- Improved the layout of chart’s setting page
- Fixed a problem related to saving to Google Drive
- Supported editing splitArea for charts
- Make the rotation anchor appear only when hover on a shape
- Fixed unable to select text in infographic after creation
- Fixed ‘Select in Tree’ behaved differently when being triggered by hotkey
Build 20210101
- Fixed wrong location for rotated chart
- Fixed IntelliJ Integration not starting Visual Paradigm
- Supported boxplot chart
- Fixed an issue related to problem commit
- Supported multiple source paths for reversing Sequence Diagram via command line (i.e. “;” for Windows, “:” for Linux)
- Keep the scroll position of page when re-activate
- Fixed unable to embed web diagram with iFrame
Build 20201218
- Fixed not showing Modeling menu in IntelliJ IDEA integration
- Added 2021 public holiday information to server
- Fixed not being asked for deleting master view
- Fixed import mermaid doesn’t work
- Fixed keyboard shortcuts not working in Sequence Diagram Text Editor (Mac)
- Fixed sync physical ERD to logical ERD generated unwanted entities
- Added color themes to InfoARTs
- Supported more sticky notes
- Fixed an XMI import issue
- Fixed unable to change color of region in map using popup
Build 20201201
- Supported page navigator for InfoART diagrams
- Improved InfoART blocks’ usability in general
- Supported different thumbnail size for different diagram categories
- Supported Background palette for InfoART
- Supported drag-and-drop behavior for charts
- Fixed bad Export PDF dialog size
- Fixed hang when opening spec. dialog on Mac
- Improved the search result when searching Artwork
- Fixed a problem related to Doc. Base
- Supported padding for region cell
Build 20201101
- Fixed export Image presents outdated Story Map
- Fixed a crash issue
- Fixed a Java Instant Reverse issue
Build 20201010
- Supported cropping shape
- Fixed a Community Edition activation issue
- Fixed Java file not generated in Java round-trip on andriod studio
- Supported Frame shapes
- Supported filter effects
- Fixed Nullable FK col being created when generating physical model
Build 20200917
- Supported tabbed layout for palette
- Fixed Split function failed to split text pasted into User Story Conversation editor
- Fixed Visual Paradigm error in import models form RSA
- Fixed wrong parent when create new diagram
- Fixed unable to create diagram form template which got multiple pages
- Fixed an application crash issue
- Fixed icon missing in exported image
- Fixed a product activation issue
Build 20200901
- Fixed unable to open Generate Swagger dialog
- Improved the look of resize handlers
- Fixed export Column Domains to Excel missed user type
- Fixed Java reverse engineering parse errors
- Fixed Eclipse Integration can’t use open JDK
- Fixed a problem with Time(0) for SQL Server
- Fixed font issue when export to PDF and printout
Build 20200801
- Fixed a problem in C# instant code generator
- Fixed being warned no permission to save diagram to server
- Fixed DSConnector connected successfully to 389 Active Directory but can not view user
- Fixed cannot save VP online exported diagram back to Teamwork Sever
- Fixed problem in business rules with glossary terms from referenced projects
- Fixed an activity fork node name visibility issue
- Fixed diagram editor corrupted when delete things
- Fixed generation of swagger fails
- Fixed a project import issue
- Fixed getter setter presentation options not refresh on diagram
