Rain
1
20240624
- Fixed cannot enable closed tabs in element’s specification dialog under Eclipse integration issue.
- Fixed Change Request didn’t send email to approver issue.
- Fixed fail to migrate VP Server issue.
- Fixed version mismatch between VP Server and DS Connector issue.
- Fixed error on remove branch project issue.
- Fixed NPE on merge between trunk/branch projects issue.
- Fixed missing data on exported Excel issue.
- Fixed stereotypes not correctly imported from MagicDraw XMI issue.
- Fixed fail to suppress numbering in TOC in Doc. Composer issue.
- Enhanced VP Server to avoid Zed proxy complain issue.
- Enhance Project Publisher dialog for publishing teamwork projects.
Rain
2
20240905
- Fixed slow on commit TOGAF Guide-through process when project having approver assigned issue.
- Fixed description area is too big in PostMania issue.
- Fixed cardinality problem when synchronize Logical to Physical ERD issue.
- Fixed incorrect tagged values being exported to Excel issue.
- Fixed unable to exclude diagram in Doc. Composer Fill-in document mode issue.
- Fixed cannot add voice file to model’s specification when computer unable to access audio device issue.
- Fixed organization chart not correctly layout when transform from business process diagram issue.
- Fixed difficult to remove custom row/column in Just-in-time process map issue.
- Introduce “Rules as list” Doc. Composer template for Decision Table issue.
- Update Polish user interface translation.
Rain
3
20241101
- Fixed missing handle entity subtype in Excel data export issue.
- Fixed Java round-trip code engineering not work on Eclipse 2024-09 integration issue.
- Fixed unable to load external images in VP Online diagrams issue.
- Enhance navigation on Zachman framework.
- Remove useless Excel export/import button in ETL table.
Rain
4
20241205
- Fixed auto save unable to restore works being done before system crash on non-workspace managed project issue.
- Fixed project template missed to handle image shape issue.
- Fixed fail delete element when perform synchronization between different level of ERDs issue.
- Fixed fail to add new tagged values to model elements from default setting issue.
- Fixed wrong permission checking causing user may not able to access User Story map issue.
- Fixed Visual Paradigm IDE integration fail to launch on IntellJ IDEA 2024.3 issue.
- Added sub-diagram menu to BPMN pool in Model Explorer tree.
Rain
5
20250101
- Fixed wrong task date on Gantt Chart issue.
- Fixed fail to generate Swagger code issue.
- Fixed fail to configure Teamwork Server/VP Online perform authentication with Azure via SAML issue.
- Fixed fail to load web base diagram from VP Server issue.
- Fixed sorting not working in file chooser dialog issue.
Rain
6
20250123
- Fixed wrong relationships created to Dependency Point issue.
- Enhance local workspace directory chooser dialog.
Rain
7
20250321
- Fixed missed to apply proxy info when acquire floating license from VP Online issue.
- Fixed reverse database to model generate duplicated stored procedure issue.
- Fixed reverse database to model missed schema property value on stored procedures and triggers issue.
- Fixed import ArchiMate model not follow original model structure issue.
- Fixed team collaboration fail to handle 50000+ modifications in single commit issue.
- Fixed Project Publisher missed to include description of Matrix Diagram issue.
- Fixed model’s tagged value not follow translation in published content issue.
- Fixed publish project to VP Online wrongly calculate storage space issue.
- Fixed Doc. Composer unable to generate Example Body for REST Request/Response issue.
- Fixed model’s specification dialog didn’t remember its previous position and size issue.
- Fixed UI Customization unable to remove Decision Table form Diagram Navigator issue.
- Support UTF-8 (with BOM) encoding for Python Instant Reverse.
- Enhance Plugin API to support specify plugin menu position using numeric value.
- Added -upgrade-project parameter to Command Line Interface.
- Support trigger Teamwork Revert Local Project via Command Line Interface.
- Enhance Simplified Chinese User Interface.
Rain
8
20250501
- Fixed unable to run Visual Paradigm on Mac due to system missing UI library issue.
- Fixed unable to run Visual Paradigm on Intel Mac OS 15.4 issue.
- Fixed import wrong model structure from Archi issue.
- Fixed export ER model to Excel missed identifying property on relationship issue.
- Fixed Java round-trip engineering fail to handle case statement with → issue.
- Fixed find and replace function not works for entity column’s default value property issue.
- Fixed delete published content won’t free up consumed space in VP Online repository issue.
- Fixed Teamwork Server/VP Online wrongly handle user’s Update Project permission issue.
- Fixed wrong page redirection on purchase license form VP Desktop client issue.
- Upgrade VP Server’s Tomcat to 9.0.10.
- Upgrade Visual Paradigm Client Embedded Server’s Tomcat to 9.0.10.
- Support generate alter statement for MS SQL Server to modify stored procedure’s parameter.
- Support suppress project version change warning in command line interface.
- Support trigger publish project to repository via Plugin API.
- Enhance performance on publish project to repository issue.
- Enhance connection mechanism for VP Client executing Scrum process over VP Online.
Rain
9
20250617
- Fixed VP Server fail to launch after upgrade to build 20250520ah problem.
- Fixed unable to open online diagrams issue.
- Fixed missing association end’s tagged values in project published content issue.
- Fixed condition expression on BPMN sequence flow not being show on diagram issue.
- Enhance PostgreSQL DDL generator on handle generate alter statement for stored procedures.
