Rain
1
20250901
- Support integration with Atlassian Confluence.
- Fixed unable to open online diagrams issue.
- Fixed unable to show error message when workspace run out-of-space during publish project issue.
- Fixed NullPointerException on update teamwork project issue.
- Fixed wrong product version number in DS Connector issue.
- Fixed unable to launch browser module issue.
- Upgrade VP Server bundled Tomcat to 9.0.108.
- Enhance Floating License Server to allow configure renew key period up to 540 minutes.
Rain
2
20250902
- Fixed cannot open AI apps issue.
Rain
3
20250906
- Fixed cannot import AI generate class diagram to project issue.
- Fixed layout of AI generated sequence diagram not correctly import to project issue.
Rain
4
20250942
- Introduce AI Chatbot modelling assistant.
- Support direct import AI apps generated diagram into current opening project.
- Fixed unable to open AI apps issue.
- Fixed unable to exit application issue.
- Fixed unable to launch AI-Assisted UML Class Diagram Generator and Smart Sequence Diagram Animator issues.
- Fixed unable to resume AI session issue.
Rain
5
20250943
- Enhance handle of connectors import from AI generated diagrams.
Rain
6
Rain
7
20251101
- Support import AI Chatbot generated Requirement Diagram, Block Definition Diagram, Object Diagram, Organization Chart into Visual Paradigm Desktop project.
- Fixed unable to load saved data in Blue Ocean Strategy app issue.
Rain
8
Rain
9
20251141
- Introduce AI Diagram generation feature for
Rain
10
20251142
- Fixed AI Diagram unable to generate Requirement Diagram issue.
- Fixed AI Diagram generate Generalization and Realization in wrong direction issue.
Rain
11
20251156
- Add AI Diagram generation support following diagram types
Rain
12
20251162
- Introduce new model-based Flowchat diagram, Gane-Sarson DFD, Yourdon & Coad DFD, Yourdon DeMacro DFD.
- Enhance project compatibility check (within version).
Rain
13
20251166
- Introduce model-based Chen Notation ERD.
- Further enhance project compatibility check (within version).
- Support generate UML Timing diagram with AI.
- Fixed exception caused by diagram palette tooltip issue.
Rain
14
20251201
- Introduce new model-based diagrams
- C4 System Context Diagram
- C4 Component Diagram
- C4 Container Diagram
- C4 Deployment Diagram
- C4 Dynamic Diagram
- C4 System Landscape Diagram.
Rain
15
20251203
- Fixed cannot fully show Technology Value for C4 diagram elements issue.
- Fixed unable to create nested Software System Scope in C4 diagram issue.
- Enhance generation of port in AI generated Internal Block Diagram.
Rain
16
20251206
- Introduce new AI features in Start Page.
- Introduce new What’s New site.
- Add AI Diagram generation support for following diagram types
Rain
17
20251211
- Fixed AI Chatbot generated return message in Sequence Diagram wrongly import as normal message issue.
- Fixed AI Chatbot generated Combined Fragment in Sequence Diagram having bad operand position issue.
- Fixed problem in What’s New dialog.
Rain
18
20251217
- Enhance diagram filter when trigger AI Diagram Generation from New Diagram dialog.
- Support trigger AI Diagram Generation from supported blank diagrams.
- Enhance prompt message for AI features in Start Page.
- Enhance Atlassian Confluence Integration
- Support list existing wiki in tree format.
- Support search exiting wiki in tree.
- Change to use attachment approach for attaching diagram to wiki.
Rain
19
20251221
- Fixed duplicated Cause and Effect Diagram entry in AI Diagram generation feature.
- Fixed Project Publisher and Doc. Composer generated wrong icons for C4 diagram’s content issue.
Rain
20
