Hi all,
after fedora 35 update to version 36 Visual Paradigm stopped running.
I decided to install VP on a newly installed fedora 36 and the problem persists.
Maybe someone can help me?
A fatal error has been detected by the Java Runtime Environment:
SIGSEGV (0xb) at pc=0x00007fe400637f7e, pid=51776, tid=51802
JRE version: OpenJDK Runtime Environment AdoptOpenJDK (11.0.10+9) (build 11.0.10+9)
Java VM: OpenJDK 64-Bit Server VM AdoptOpenJDK (11.0.10+9, mixed mode, tiered, compressed oops, g1 gc, linux-amd64)
Problematic frame:
C [libharfbuzz.so+0x37f7e] hb_font_get_font_v_extents_default(hb_font_t*, void*, hb_font_extents_t*, void*)+0xe
Core dump will be written. Default location: Core dumps may be processed with “/usr/lib/systemd/systemd-coredump %P %u %g %s %t %c %h” (or dumping to /home/administrator/Scaricati/Visual_Paradigm_16_3_20220503_Linux64.sh.51735.dir/core.51776)
An error report file with more information is saved as:
/home/administrator/Scaricati/Visual_Paradigm_16_3_20220503_Linux64.sh.51735.dir/hs_err_pid51776.log
If you would like to submit a bug report, please visit:
GitHub · Where software is built
The crash happened outside the Java Virtual Machine in native code.
See problematic frame for where to report the bug.
./Visual_Paradigm_16_3_20220503_Linux64.sh: riga 594: 51776 Annullato (core dump creato) $INSTALL4J_JAVA_PREFIX “$app_java_home/bin/java” -Dexe4j.moduleName=“$prg_dir/$progname” -Dexe4j.totalDataLength=761379330 -Dinstall4j.cwd=“$old_pwd” “-Dsun.java2d.noddraw=true” $INSTALL4J_ADD_VM_PARAMS -classpath “$local_classpath” install4j.Installer647934017 “$@”
