Hi!
When I try to open the Visual Paradigm in VB to generate a UML model before the code it´s stay in an infinity open procedure and just not open the Visual Paradigm.
Any ideas?
Thankz!
Hi!
Any ideas?
Thankz!
Dear Lucas_de_Souza,
Thank you for your inquiry. We would like to collect your log file for checking. Could you start Visual Paradigm, export the log file the About window (Help > About) and then upload to the following folder?
https://files2.visual-paradigm.com/index.php/s/DPUiA52A0XxxOQr
Password: n8fnkjdsg9ndg
Note: Only Visual Paradigm support team will have access to your uploaded file.
Hi, Jick!
Please, verify if you received the file .zip.
Thankz,
Hi Lucas_de_Souza,
Yes, we have received your file. Thank you. According to the log file, it looks like there is a file that failed to be copied to your Visual Studio directory. This kind of problem could be caused by a lack of admin permission in running the IDE. Could you try running Visual Studio with admin right? (i.e. right-click on the Shortcut and select Run as Administrator)
