I am not a beginner programmer but a beginner VB.Net programmer. When would it be appropriate to get into UML? Also, what is the right sequence for learning VB? Is studying OOA/D/P early right or should I study ADO.NET, ASP.NET before OOA/D/P, then UML, then ADO.NET, ASP.NET?
Funny enough UML is always related to developers. This is not always the case.
I would suggest you get up to speed with UML, it will give you a feeling on how to convert a business problem into a software solution (if that is what you want) Most code cutters will have to retrain their brain when starting on UML and OO so i guess starting with UML and OO is a good way of approaching it.
But the end of the day it depends on the person, why not learn how th build classes in UML and use the code output to learn VB.Net?
