Rain
#1
Build no: 20051020
- Fixed Importing Rose Project (Model Only) throws exception.
- Fixed duplicated tagged values in stereotype when committing project to teamwork server.
Build no: 20051020
- Fixed Instant Reverse Java Class invalid characters crash project when save problem
- Fixed database connection with JTurbo driver problem.
- Fixed cannot multiple select and move shapes in sequence diagram.
- Fixed delete frame or interaction occurrence not delete associated gates problem.
Build no: 20050624z
- Fixed C++ Instant Reverse not support nested class problem.
- Fixed SDE-VS create delegate from model failed to synchronize to code problem (C#).
- Fixed copy and paste across projects may cause duplicated models problem.
- Fixed SDE-NB diagram tab won’t refresh after renamed problem.
- Fixed SDE-VS VB.NET namespace with different case treated as different namespace problem.
- Fixed Report Writer didn’t support documentating child state problem.
- Fixed diagram overview shape presentation option not handled in project merge and teamwork problem.
- Fixed cannot remove associated diagram of diagram overview shape problem.
Build no: 20050624y
- Enhanced datatype conversion in Class Diagram/ERD synchronization. Now compatible datatypes will in ERD/Class model will not be updated.
- Fixed gradient of genericshape on Mac problem.
- Fixed event of state not being imported from XMI problem.
- Fixed add files to model in open specification not saved problem.
- Fixed default look & feels problem on Solaris.
- Fixed remove operand in manage operands dialog caused exception.
Build no: 20050624w
- Enhanced synchronization between Class Diagram and ERD.
- Support showing warning dialog when creating index with incorrect type mapping in ERD.
- Fixed smart resource of DecisionNode does not expand on mouse over problem.
- Fixed create combined fragment using diagram toolbar will have incorrect initial location problem.
- Fixed add existing diagrams as sub-diagrams using popup menu not work problem.
- Fixed incorrect class presentation options when loading project from prior versions problem.
- Fixed generate persistence code from database create empty class diagram problem in SDE for IntelliJ IDEA.
Build no: 20050624v
- Fixed JDBC Instant Reverse problem.
- Fixed send sequence diagram shapes to an existing sequence diagram activations moved to top problem.
- Fixed calculation of new shape location when single-click on resource may cause program hangs problem.
Build no: 20050624u
- Support Force Update Model from source code.
- Fixed Instant Reverse create duplicated operations when reverse from same source problem.
- Fixed Combo box Look and Feel problem.
- Fixed focus problem when importing license in Mac OS X.
- Fixed License Key Manager filter out .vpl extension problem.
- Fixed installation problem in VP-UML IntelliJ IDEA integration.
- Fixed several minor problems in Use Case Details Editor.
Build no: 20050624t
- Support Force Update Model from Code.
- Fixed SDE-VS 2003 VB update property setter parameter type bug.
- Fixed diagram overview shape shows black background problem.
- Fixed set shape to transparent using popup menu caused exception.
- Fixed index column of foreign key connector not moved to new “to” table if “to” table is changed.
- Fixed showing nullable in ERD report and documentations of messages in Sequence diagram report (HTML/PDF)
- Fixed CRC Card’s font problem in Mac & Linux
Build no: 20050624s
- Fixed copy swimlane (UML 2.0) and paste not share model caused exceptions.
- Fixed reverse db bug when user name is different from schema name.
- Fixed add “Any Receive Event” in State open specification dialog failed problem.
- Fixed open add existing diagrams dialog from sub-diagram popup menu does not filter diagrams from allowed sub-diagram types.
Build no: 20050624r
- Support reverse unique constraint from DB.
- Fixed wrong calculation of parent when move package inside class diagram with default package.
- Fixed use case details diagram preview ugly problem.
- Fixed export diagram as image lost gradient color problem.
- Fixed gradient paint pattern does not follow zoom ratio problem.
- Fixed change from/to table of foreign key connector involving partial table caused problem.
- Fixed SDE-NB on NetBeans JSP project missing code completion problem.
Build no: 20050624q
- Fixed Exception when generating ORM code with persistable class extends normal class.
- Fixed cannot connect object flow from output pin to expansion node.
- Fixed DB table with multiple FK reference to the same table, reversed only 1 FK.
- Fixed synchronize ERD to class diagram, entity with multiple FK reference to the same entity will generated multiple associations with the same name.
- Fixed export diagram as EMF cannot overwrite existing file.
Build no: 20050624p
- Fixed exported project z-order of shapes wrong problem.
- Fixed shapes do not fit size after layout even when diagram is set to auto fit shapes size.
- Fixed tagged values do not refresh after added/removed tagged value definitions of the related stereotype.
- Fixed copy use case with model will share the same use case details problem.
- Fixed use case details editor does not refresh when the use case model is changed externally.
- Fixed problem of getting project source path in EJB module project of SDE-NB.
Build no: 20050624n
- Fixed when re-associate overview diagram shape, old diagram being renamed as new diagram name problem.
- Fixed component object name does not refresh in diagram after assigned base classifier.
- Fixed drag and drop of models in tree does not fire project modified.
- Fixed recent project list wrong items listed problem.
- Fixed ask recover project dialog behind splash screen in Linux.
- Fixed multiplicity bounds not handled in teamwork server and project export.
- ORM generate POJO changed visibility of ID getter to public
- Fixed jump to related model in open specification dialog wrong navigation behavior.
- Fixed calculate backup project file name bug.
Build no: 20050624k
- Fixed some default options set do not get applied to the diagram.
- Fixed export diagram as images problem on SDE-VS.
- Fixed generate invalid servlet filter class name if project name contains space.
- Improved error handling on create database.
- Fixed option dialog allows user to select different Look & Feels problem on SDE.
Build no: 20050624g
- Fixed class size change on diagram deactivation when the diagram is set to auto fit shapes size and in zoomed out state.
- Fixed problem caused by several problem fonts.
- Fixed spelling mistakes in tooltips of resources.
Build no: 20050624f
- Added support to IntelliJ IDEA 5.0
- Support copy diagram elements into system clipboard as EMF (Windows platform).
- Support diagram based auto fit size for all shapes.
- Support reverse SQL Server uniqueidentifier primary key. It will use new “guid” as id generator and map to Java String type.
- Fixed Report Writer generate Use Case Description items in wrong order problem.
- Fixed Report Writer doesn’t generate the correct flow of events item name.
- Fixed drag-and-drop of actor and life line from a sequence diagram (in Diagram Navigator) to another sequence diagram no shape created problem.
- Fixed parent-child relationships between package-class or class-class defined using containment connector will lost after reopening the project.
- Fixed export timing diagram as image timing frame painting problem.
- Fixed copy to clipboard as image of sequence diagram will cause activations to be painted below life lines problem.
- Fixed ORM Pane Database view cannot handle table name with space.
Build no: 20050624e
- Import Rose support associate state diagram, activity diagram as package’s sub-diagram.
- Added POJO option to ORM code generation.
- Fixed export of project lose rich-text format of documentation.
- Fixed some minor diagramming related problems.
