Build 20111111
These changelog for VP Suite demonstrate the enhancements provided in the following products up to and including Build 20111111.
Changes since Build 20111103
Build 20111111
Build 20111118
These changelog for VP Suite demonstrate the enhancements provided in the following products up to and including Build 20111118.
Changes since Build 20111111
Build 20111126
Products
Visual Paradigm for UML 8.3 Service Pack 1
Smart Development Environment 6.3 Service Pack 1
Business Process Visual ARCHITECT 4.3 Service Pack 1
DB Visual ARCHITECT 6.3 Service Pack 1
Agilian 3.3 Service Pack 1
DB Visual ARCHITECT SQL 1.0
Fixes and Enhancements
Documentation Editor
Fixed element link lost when setting bullet point after it
Fixed several delete and undo actions may crash the editor
Fixed incorrect cursor position after creating new line in list item
Fixed unable to read model element link for the documentation of referenced model element
Fixed a new line is produced when copy and paste model element links within a list
Fixed list item lost when pressing Delete and Enter at the end of list item
Fixed unable to break consecutive model element links added to editor
Fixed converting referenced model element to mirror loose model element link
Fixed duplicating referenced element loose model element link added in editor
Fixed position of bad line break caused by consecutive model element links
General Modeling
Fixed non selected lane and tasks move together when moving other shapes
Fixed text in nodes aren’t shown (only for JDK 1.7)
Fixed unable to all elements in Model Explorer (project specific)
Fixed strange user defined tagged value is created
Fixed connectors produced by visualizing related elements does not show stereotype
Fixed Visual Diff failed to show the change of attribute type
Fixed getting stuck when configuring programming language
Fixed data type incorrectly appended with number after configure programming language
Fixed deleting shapes duplicated from referenced project cause the connectors in referenced project be deleted
Fixed removing stereotype not remove tagged values from classes that use the stereotype
Supported double-clicking on warning in message pane to locate the view where referenced model element is missing
Supported creating instance specification by repeating the action (F3) of dragging and dropping class from trees
Report Generation/Editing
Fixed unable to generate Word report (project specific)
Fixed unable to publish project (project specific)
Fixed a problem related to reading project publisher outcome in Internet Explorer 9
Fixed Word report generation unexpectedly added a line break in front of any list added to HTML documentation
Fixed unable to show attributes in generated Word report (related to the structuring of report template)
Fixed Hyperlink exported to Word report from report composer does not support non-english characters
Code Engineering
Fixed instant reverse XSD wrongly produced a self association on a class
Enhanced instant generator to generate getter and setter implementation
ORM and Hibernate
Fixed class diagram and ERD produced by generating code via ORM wizard aren’t synchronized by default
Supported “not” expression for Hibernate criteria
Image Exporting
Fixed an encoding issue for exported SVG
ArchiMate
Supported bi-directional access in ArchiMate
Team Collaboration
Supported ordering user projects in Teamwork Server user administration page alphabetically
Enhanced the commit process to consume less memory
Improve the warning of importing invalid key file into Teamwork Server during installation
Miscellaneous
Updated Czech language file
Changed to read machine-wide workspace setting file instead of installation-wide
Build 20111203
Products
Fixed documentation editor failed to present model element for elements in referenced project
Fixed inconsistent split behavior for unordered list in documentation editor, when pressing Enter
Fixed deleting empty space in documentation editor cause subsequent model element link be deleted
Fixed numbered list is crashed after several key actions in HTML editor
Fixed cut and paste sub-list-item to another list item place cursor to wrong position
Improved the warning message to show when switching from HTML to Plain Text
Profile, Stereotype and Tagged Values
Fixed missing stereotype in sub-level tagged value
Fixed missing linkage between attribute and association for class duplicated from referenced project
Fixed duplicate a mirror element produce multiple 'Transit From’
Fixed removing stereotype from requirement wrongly removes attributes (i.e. tagged values) that are shared with another stereotype
Added a project option for removing tag from model element when removing tagged value definition, if tag’s value is modified
General Modeling
Fixed delete view incorrectly delete model element despite ‘keep model element’ is selected during deletion
Fixed undo visualizing multiple elements remove only 1 element
Fixed unable to cut elements with Ctrl-X (project specific)
Fixed cut and paste elements may throw exception
Fixed broken connector when moving shapes downwards with hotfix
Fixed undo show dependency from operation cause element be deleted from Model Explorer
Fixed Visual Diff failed to show the change of multiplicity
Fixed unable to create gate to interaction use in sequence diagram
Fixed Model Explorer shows ‘null : ${class-name}’ for object node created from class via drag and drop from model explorer/diagram navigator
Fixed create BPD under a model wrongly prompted me for the need of loading lots of model elements
Fixed copy callout content and paste as plain text embeds strange hidden character for indentation
Supported showing gate in sequence diagram referenced by interaction use that has gate attached to its border
Improved application performance in BPD by removing redundant checking
Disallowed realizing brainstorm notes back to brainstorm diagram
State Machine Diagram
Fixed sub machine not put under sub machine state (model level)
Fixed state machine diagram selection lost when clicking on drop down menu of submachine state’s submachine property
Supported outgoing state resource for entry point in state machine diagram
Fixed incorrect image size for images in report writer’s report
Fixed ‘generate (with subordinate)’ does not work in report generator’s template editor
Project Referencing
Fixed wrong project used for ‘Transit From’ when duplicate model element from referenced project
Fixed role name is missing when creating composition between stereotypes in profile diagram
Code Engineering
Fixed C++ instant generator wrongly added underscore to data type that has space
Team Collaboration
Fixed Teamwork Server migrate miss out JDBC jar for SQL Server
Fixed an error in migrating Teamwork Server
Supported dragging multiple teamwork files node (for performing mass actor like moving multiple files)
Build 20111208
Products
General Modeling
Fixed presentation has no effect for class that show in non-class diagram
Fixed show attribute and association from attribute from class that put near the diagram border does not cause the diagram to expand to show the visualized class
Fixed unable to handle parallel gateway in Simulacian
Fixed activation may step over termination sign in sequence diagram
Supported moving caption of gate in sequence diagram
Fixed bad rendering of rule family table in report composer
Fixed PDF report generation may miss out some pages
Improved the layout of rule family table in generated HTML report when having empty conditions columns
Supported not to show quality information in report generated from report generator
Supported not to show quality information in web contents published from project publisher
ORM and Hibernate
Fixed driver description for incorrect port information for DB2 type 4 driver
Supported personalizing database connection settings to aid in team collaboration
Impact Analysis
Supported showing class member when analyzing class
Miscellaneous
Fixed repair project clears logical view
