VP hangs while saving
2 out of 5 times, when I press “save” on VP 16.3, I get a rotating wheel that spins forever and the program becomes totally unresponsive, so all I can do is kill the process.
This happens both to a M1 and an Intel i7 Mac
  • Context 1: Macbook Pro M1 (2020), 16 GB RAM, Macos Monterey 12.01
  • Context 2: iMac i7 (2018), 40 GB RAM, Macos Monterey 12.2
The good news is that autosave works!
The bad news is that I need to reset the floating license every time, which is really annoying…
Vassilios
I had a similar bug, which was solved in latest VP.
See
Thanks for the reply. Unfortunately this has been happening for a couple of updates back, and the thing is that it seems to be worse with the latest update.
What is most annoying is that I cannot link it to the M1, it happens all the same with my Intel Mac.
Let’s see what the VP people will say…
Thanks again,
V
Did you tried to alter the vplauncher.vmoptions properties setting? I am working on windows/intel and experiencing the same issue, but after that change, it totally vanished. The symptoms were the same, during save the application froze, and only a task kill solved the problem.
Can you please let me know how do I do that?
Thanks!
V
I don’t own a Mac, so that’s what I found on the internet, but the file location is the following:
~/Library/Application Support/VisualParadigm/vplauncher.vmoptions
This is a text file, you can edit with a text editor. Open it, and add the following line at the end of the file in a new line:
-Djdk.tls.client.protocols=TLSv1.2
Then start visual paradigm, and let’s see what happens. Probably should try it out with a test model, and not the real system.
