Hello
I use Windows 11, IntelliJ Ultimate 2021.3.2 and Visual Paradigm 16.3.
I’m trying to open/start VP in IntelliJ. I already installed the IntelliJ integration via VP and that was succesfully installed. When I try to open the VP Integration in IntelliJ, I get this error:
at v.dbt.c.a(:98)
at v.dbt.x.b(:320)
at v.dbt.x.a(:208)
at v.dcl.b.a(:48)
at v.dat.c.a(:43)
at v.dat.c.actionPerformed(:29)
at com.intellij.openapi.actionSystem.ex.ActionUtil.lambda$performActionDumbAwareWithCallbacks$4(ActionUtil.java:244)
at com.intellij.openapi.actionSystem.ex.ActionUtil.performDumbAwareWithCallbacks(ActionUtil.java:265)
at com.intellij.openapi.actionSystem.ex.ActionUtil.performActionDumbAwareWithCallbacks(ActionUtil.java:244)
at com.intellij.openapi.actionSystem.impl.ActionMenuItem$ActionTransmitter.lambda$performAction$0(ActionMenuItem.java:277)
at com.intellij.openapi.wm.impl.FocusManagerImpl.runOnOwnContext(FocusManagerImpl.java:236)
at com.intellij.openapi.wm.impl.IdeFocusManagerImpl.runOnOwnContext(IdeFocusManagerImpl.java:67)
at com.intellij.openapi.actionSystem.impl.ActionMenuItem$ActionTransmitter.performAction(ActionMenuItem.java:269)
at com.intellij.openapi.actionSystem.impl.ActionMenuItem$ActionTransmitter.actionPerformed(ActionMenuItem.java:284)
at java.desktop/javax.swing.AbstractButton.fireActionPerformed(AbstractButton.java:1967)
at com.intellij.openapi.actionSystem.impl.ActionMenuItem.lambda$fireActionPerformed$2(ActionMenuItem.java:111)
at com.intellij.openapi.application.TransactionGuardImpl.performUserActivity(TransactionGuardImpl.java:94)
at com.intellij.openapi.actionSystem.impl.ActionMenuItem.fireActionPerformed(ActionMenuItem.java:111)
at com.intellij.ui.plaf.beg.BegMenuItemUI.doClick(BegMenuItemUI.java:541)
at com.intellij.ui.plaf.beg.BegMenuItemUI$MyMouseInputHandler.mouseReleased(BegMenuItemUI.java:571)
at java.desktop/java.awt.Component.processMouseEvent(Component.java:6654)
at java.desktop/javax.swing.JComponent.processMouseEvent(JComponent.java:3345)
at java.desktop/java.awt.Component.processEvent(Component.java:6419)
at java.desktop/java.awt.Container.processEvent(Container.java:2263)
at java.desktop/java.awt.Component.dispatchEventImpl(Component.java:5029)
at java.desktop/java.awt.Container.dispatchEventImpl(Container.java:2321)
at java.desktop/java.awt.Component.dispatchEvent(Component.java:4861)
at java.desktop/java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4918)
at java.desktop/java.awt.LightweightDispatcher.processMouseEvent(Container.java:4547)
at java.desktop/java.awt.LightweightDispatcher.dispatchEvent(Container.java:4488)
at java.desktop/java.awt.Container.dispatchEventImpl(Container.java:2307)
at java.desktop/java.awt.Window.dispatchEventImpl(Window.java:2790)
at java.desktop/java.awt.EventQueue.dispatchEventImpl(EventQueue.java:778)
at java.desktop/java.awt.EventQueue$4.run(EventQueue.java:727)
at java.desktop/java.awt.EventQueue$4.run(EventQueue.java:721)
at java.base/java.security.AccessController.doPrivileged(Native Method)
at java.base/java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:85)
at java.base/java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:95)
at java.desktop/java.awt.EventQueue$5.run(EventQueue.java:751)
at java.desktop/java.awt.EventQueue$5.run(EventQueue.java:749)
at java.desktop/java.awt.EventQueue.dispatchEvent(EventQueue.java:748)
at com.intellij.ide.IdeEventQueue.defaultDispatchEvent(IdeEventQueue.java:891)
at com.intellij.ide.IdeEventQueue.dispatchMouseEvent(IdeEventQueue.java:820)
at com.intellij.ide.IdeEventQueue._dispatchEvent(IdeEventQueue.java:757)
at com.intellij.ide.IdeEventQueue.lambda$dispatchEvent$6(IdeEventQueue.java:447)
at com.intellij.openapi.progress.impl.CoreProgressManager.computePrioritized(CoreProgressManager.java:818)
at com.intellij.ide.IdeEventQueue.lambda$dispatchEvent$7(IdeEventQueue.java:446)
at com.intellij.openapi.application.impl.ApplicationImpl.runIntendedWriteActionOnCurrentThread(ApplicationImpl.java:805)
at com.intellij.ide.IdeEventQueue.dispatchEvent(IdeEventQueue.java:498)
at java.desktop/java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:203)
at java.desktop/java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:124)
at java.desktop/java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:113)
at java.desktop/java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:109)
at java.desktop/java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:101)
at java.desktop/java.awt.EventDispatchThread.run(EventDispatchThread.java:90)
