I’ve tried to upgrade to SDE 5.2 community edition for Netbeans 6.8 (having successfully installed SDE 5.1 community edition last week) but now in SDE 5.2 when the installer prompts me to specify the root installation directory for Netbeans, it does not accept the path I specify (which is definitely correct - being the default value /Applications/NetBeans). Is there a workaround for this?
Hi user,
Thanks for your post. As you install a new version of SDE, please uninstall the old version (SDE 5.1) before installing SDE 5.2. Otherwise, you will not be able to install SDE 5.2 on the same NetBeans since you cannot install more then one SDE/DB-VA on same IDE.
If you have any further question, please do not hesitate to contact me.
hi,
i have de same problem but in my case is the first time i try to install it. What can i do?
Hi user,
Could you upload a few screenshots to show how does the NetBeans selection being rejected?
Hi Jick,
i couldn’t upload the screen-shoots here but i put it in my megaupload account check this link: http://www.megaupload.com/?d=D4TN1YIS.
Regards,
sam
Hi user,
We cannot access the page. It said:
This service is temporarily not available from your service area.
How about you register to post a reply with attachment? Alternatively, you can create a ticket at:
http://www.visual-paradigm.com/support/technicalsupport.jsp
Hi jick,
sorry there is a dot (.) at de end of the link that’s wy you can not acess de link try again here please: http://www.megaupload.com/?d=D4TN1YIS
Regards,
sam
Hi Sam,
The result is the same as before. Could you register to post a reply with attachment?
