at the end of last week i tried to install and run VP_Suite 4.1 on an ubuntu linux 9.04 on a 64bit maschine.
The Installation succeeded but when i try to create a diagram in an helloworld c++ project it freezes eclipse completly.
Today i tried the same on a ubuntu 9.10 32 but mschine, but i got the same error.
Is there a fix for this or am i doing something wrong ?
Thanks for your message. May I know whether you are using Eclipse CDT?
If so, could you please try installing on Eclipse JDT and see if you have the same problem?
I have a similar problem on Ubuntu 9.10 x64 with VP_Suite4.2. I selected “Open SDE-EC” option in context menu. Clicked OK button in the Project Structure dialog freezes the Eclipse completely. I can close them only by the kill command.
Thanks for replying with the files. I’ve forwarded the details to our engineers to check, and I’ll come back to you once there is any feedback.
By the way, you said your post was lost, but actually is because you posted reply without login. All posts from Anonymous will need to wait for moderated - and it’s now on this forum topic!
Our engineers checked your log files and found that you are using OpenJDK. Please try to use bundled JRE to run Eclipse (by the following command) and see if the problem can be solved?
No, I did not use JDK, included in VP Suite because I have no jre folder in the Eclipse folder. I have not been assured that copying jre from VP_Suite into my Eclipse folder will not spoil my Eclipse installation. It is more important for me.
