I’m trying to write some units test, so I decide to use different database.
I saw that PersistentManager implementation exposes setJDBCConnectionSetting method. So I wrote the following code:
JDBCConnectionSetting settings = new JDBCConnectionSetting();
settings.setDriver(org.hsqldb.jdbcDriver.class.getName());
settings.setConnectionURL("jdbc:hsqldb:mem:ProductDAOTest");
settings.setUserName("sa");
settings.setDialect(HSQLDialect.class.getName());
GestionePersistentManager.setJDBCConnectionSetting(settings);
Simple, but when I launch debug it alway throws new ClassNotFoundException. The message is: JDBC Driver class not found.
But I’m absolutely sure that the driver file is correctly in path.
May I know how did you configure the connection, and how do you make sure that the driver file is in correct path?
[/quote]
About the path… I include hsqldb.jar via Intellij Idea. It launch class file with java -classpath /usr/share/java/hsqldb.jar …
Here Connection configuration is:
