Hello, I’m looking for a tool that will allow me take an XSD and create POJO classes, not xmlbeans. Is it possible to use Visual Paradigm for this? XSD -> UML and then UML -> Java?
I have access to Visual Paradigm 13.1 …
Thanks for any help!
You can use Instant Reverse to reverse XSD to Class.
Then use Instant Generator to generate Java from Class.
Thank you for using Visual Paradigm.
Thanks @ roykeung. I’m finally getting a chance to try this, but as I’m brand new to VP, so I’m a little confused. When I choose Tools -> Instant Reverse - I don’t see an option for adding an xsd, which is my starting point. And, am I reversing to a Class Diagram, before invoking the Instant Generator?
Thanks,
Mike
OK - never mind the last question, I figured out how to use Instant Reverse with an xsd. But I’m getting an Unknown error. Are there any logs to check that might give more specifics?
Could you send us the XSD for us to further investigate?
If possible, please send it to: support-team@visual-paradigm.com
and include the link to this post in the email.
