What database types does Visual Paradigm support?
i.e. various versions of …
Oracle?
MS SQL Server?
MySQL
etc.
I ask this question as I noted that Visual Paradigm ERD changes some data types from MS SQL Server 2017 … e.g. timestamp to datetime … (actually this is the only datatype I have found changed so far).
I’m starting to like this product more and more. Am doing a trial but think I will plan to buy a license !
(This might relate to the JDBC driver I have chosen for reverse engineer).
Actually all versions of our listed DB should be supported (detail behavior could subject to the JDBC driver), and the version options in Database Configuration dialog is only affecting the variation on the datatype. For example, for SQL Server with version 2005 will have both datetime and timestamp as the standard data type, but switch to 2008 then the timestamp will consider as optional type (show in italic font in column specification dialog) since it is just synonym of rowversion. As long as the DB can handle those synonym then user should not experience any problem on it.
