Hi
I reversed engineered a large client DB into VP. Because of the number of tables, I want to create many ERDs, each covering a “topic” area.
When I drag a table from the Model into my diagram, I see that some columns are foreign keys. I then want to add their primary tables into this diagram.
However, the initial database creators were very original in naming the columns. For example, a column DEPARTMENT may actual refer to the DIVISION table. This one is easy, other are way more obscure, such as a column TYPE that refer to one of about 20 tables named xyz_TYPE (but which one?).
My question is how can I see the definition of the Foreign Key relation without having to drag all tables into my diagram to have VP show the defined relation?
