Whenever I open the flowchart file that is being saved in my local folder, VP shows up an error message like the below.
The only way I can open the flowchart is thru the file that is in teamserver’s local folder.
Even after I save the flowchart in the folder I selected, it fails to open the file again.
Sorry we’re late in responding. We tested around the creation, saving and opening of diagrams, including flowcharts and some other diagram types, but were unable to repeat the issue you described. Since it’s been a while since you last reported this issue, I’m wondering if this issue is still repeatable?
The VP application is not connect to repository which hosting your project
Your VP application is connected to a repository which not hosting your project
To diagnose the actual case would you please send me your log files for checking? You can export them from the Help > About dialog of your VP Application. You can send your log files to support@visual-paradigm.com in case you don’t want to disclose them in the forum. Look forward to hearing from you.
