I’m using VisualParadigm 16.3, mac bigsur. I found sometimes new attributes(option+shift+A) doesn’t work. and after reboot the app, it will work again. but you don’t know when it will failed to work.
I tried define another shortcut, but the problem is still there.
Thank you for your inquiry. Could you send us your log file to take a look? You can export log file from the About window (Help > About). Then, please upload the exported zip file to: https://files2.visual-paradigm.com/index.php/s/BKTQb245rWnCsq5
Password: kjbrfugf0nbjdfr34
Thank you for your log file. The log looks fine and unfortunately, we are unable to repeat the problem on our Macs… Do you recall what you have done right before the problem occurred?
I upload a new log file. you can see:
16:42. I open VP
I create a class, and create new attribute through shortcut. it works.
I just create 3 attributes, move the class.
then I leave and work on other app.
17:36: I return to VP, and found the shortcut doesn’t work. you can see the NullPointerException
BTW. this happened in my old MBP. and also happened in my new MBP.
