Hello Jick,
thanks for your help, so vp.log says:
snipp--------------->>>>>>>>>>>>
[Sun Jun 03 11:15:04 CEST 2007] [message] [Sun Jun 03 11:15:03 CEST 2007]: Start Visual Paradigm for UML Enterprise Edition [VP-UML EE]: 6.0 (sp2_20070526)
[Sun Jun 03 11:15:11 CEST 2007] [message] [Sun Jun 03 11:15:11 CEST 2007]: Start Visual Paradigm for UML Enterprise Edition [VP-UML EE]: 6.0 (sp2_20070526)
and now hs_err_pid16349.log:
An unexpected error has been detected by HotSpot Virtual Machine:
SIGSEGV (0xb) at pc=0x00002aaab2f04462, pid=16349, tid=1078745440
Java VM: Java HotSpot™ 64-Bit Server VM (1.5.0_10-b03 mixed mode)
Problematic frame:
C [libz.so.1+0xa462] inflateEnd+0x32
--------------- T H R E A D ---------------
Current thread (0x00000000401b4e90): JavaThread “Finalizer” daemon [_thread_in_native, id=16358]
siginfo:si_signo=11, si_errno=0, si_code=128, si_addr=0x0000000000000000
Registers:
RAX=0xee854c4200000000, RBX=0x00002aaab024fda0, RCX=0x00002af80be95c40, RDX=0x6666c3c95b08c483
RSP=0x00000000404c42d0, RBP=0x00000000404c42f0, RSI=0x6666c3c95b08c483, RDI=0x0000000000000000
R8 =0x00002af80be994b0, R9 =0x00002af80be945a0, R10=0x0000000000000000, R11=0x00002aaab2f04430
R12=0x00000000401b4fe0, R13=0x00002af832c41530, R14=0x00000000404c4378, R15=0x00000000401b4e90
RIP=0x00002aaab2f04462, EFL=0x0000000000010202, CSGSFS=0x0000000000000033, ERR=0x0000000000000000
TRAPNO=0x000000000000000d
Top of Stack: (sp=0x00000000404c42d0)
0x00000000404c42d0: 00002aaab024fda0 00002af80c8e172f
0x00000000404c42e0: 00002af832c41530 00002af80f97d540
0x00000000404c42f0: 00000000404c4350 00002af80f97d562
0x00000000404c4300: 00000000401b4e90 00000000401b5198
0x00000000404c4310: 00000000401b4e90 00000000404c4318
0x00000000404c4320: 00002af832c41530 00000000404c4378
0x00000000404c4330: 00002af832c419c0 0000000000000000
0x00000000404c4340: 00002af832c41530 00000000404c4370
0x00000000404c4350: 00000000404c43c8 00002af80f973efe
0x00000000404c4360: 00002af832c41910 00002af80f97a498
0x00000000404c4370: 00002aaab024fda0 00002af8154cb788
0x00000000404c4380: 0000000000000009 00002af8154cb788
0x00000000404c4390: 00000000404c4380 00002af832c40ccd
0x00000000404c43a0: 00000000404c43d8 00002af832c419c0
0x00000000404c43b0: 0000000000000000 00002af832c40ce8
0x00000000404c43c0: 00000000404c43d8 00000000404c4418
0x00000000404c43d0: 00002af80f973efe 00002af8154cb788
0x00000000404c43e0: 00000000404c43e0 00002af832c40d99
0x00000000404c43f0: 00000000404c4428 00002af832c419c0
0x00000000404c4400: 0000000000000000 00002af832c40da8
0x00000000404c4410: 00000000404c4428 00000000404c4490
0x00000000404c4420: 00002af80f97132d 00002af8154cb788
0x00000000404c4430: 0000000000001fa0 00000000404c44d0
0x00000000404c4440: 00000000404c4640 00000000401b4e90
0x00000000404c4450: 00002af80be9a678 00002af80f9712a9
0x00000000404c4460: 00000000404c4500 00000000404c4798
0x00000000404c4470: 000000000000000a 00002af832c40da8
0x00000000404c4480: 00002af80f97bb60 00000000404c4648
0x00000000404c4490: 00000000404c4580 00002af80b9c1275
0x00000000404c44a0: 0000000000000001 00000000401b4e90
0x00000000404c44b0: 00000000404c4500 00000000404c4798
0x00000000404c44c0: 0000000a00000000 00002af80f97bb60
Instructions: (pc=0x00002aaab2f04462)
0x00002aaab2f04452: 48 8b 56 40 48 85 d2 74 11 48 89 d6 48 8b 7f 50
0x00002aaab2f04462: ff d0 48 8b 73 38 48 8b 43 48 48 8b 7b 50 ff d0
Stack: [0x00000000403c5000,0x00000000404c6000), sp=0x00000000404c42d0, free space=1020k
Native frames: (J=compiled Java code, j=interpreted, Vv=VM code, C=native code)
j java.util.zip.Inflater.end(J)V+0
j java.util.zip.Inflater.end()V+13
j java.util.zip.Inflater.finalize()V+1
v ~StubRoutines::call_stub
V [libjvm.so+0x385275]
V [libjvm.so+0x55f719]
V [libjvm.so+0x385085]
V [libjvm.so+0x3b29d9]
V [libjvm.so+0x396c6d]
C [libjava.so+0xf98f] Java_java_lang_ref_Finalizer_invokeFinalizeMethod+0x5f
j java.lang.ref.Finalizer.invokeFinalizeMethod(Ljava/lang/Object;)V+0
j java.lang.ref.Finalizer.runFinalizer()V+45
j java.lang.ref.Finalizer.access$100(Ljava/lang/ref/Finalizer;)V+1
j java.lang.ref.Finalizer$FinalizerThread.run()V+11
V [libjvm.so+0x384b58]
V [libjvm.so+0x384be6]
V [libjvm.so+0x403a8e]
V [libjvm.so+0x61d4be]
V [libjvm.so+0x560065]
Java frames: (J=compiled Java code, j=interpreted, Vv=VM code)
--------------- P R O C E S S ---------------
Java Threads: ( => current thread )
0x00002aaab03d0a30 JavaThread “Image Fetcher 0” daemon [_thread_blocked, id=16371]
0x00002aaab03d0780 JavaThread “TimerQueue” daemon [_thread_blocked, id=16370]
0x0000000040117980 JavaThread “DestroyJavaVM” [_thread_blocked, id=16349]
0x00002aaab0462bd0 JavaThread “Thread-2” [_thread_in_vm, id=16369]
0x00002aaaaabe4f00 JavaThread “AWT-EventQueue-0” [_thread_blocked, id=16368]
0x00002aaab0442ca0 JavaThread “AWT-Shutdown” [_thread_blocked, id=16367]
0x00002aaab024bdb0 JavaThread “AWT-XAWT” daemon [_thread_in_native, id=16366]
0x00002aaab0528d10 JavaThread “Java2D Disposer” daemon [_thread_blocked, id=16365]
0x00002aaaaabde6f0 JavaThread “Low Memory Detector” daemon [_thread_blocked, id=16363]
0x00002aaaaabdcb50 JavaThread “CompilerThread1” daemon [_thread_blocked, id=16362]
0x00002aaaaabdb630 JavaThread “CompilerThread0” daemon [_thread_blocked, id=16361]
0x00002aaaaabd9f60 JavaThread “AdapterThread” daemon [_thread_blocked, id=16360]
0x00002aaaaabd8df0 JavaThread “Signal Dispatcher” daemon [_thread_blocked, id=16359]
=>0x00000000401b4e90 JavaThread “Finalizer” daemon [_thread_in_native, id=16358]
0x00000000401b46b0 JavaThread “Reference Handler” daemon [_thread_blocked, id=16357]
Other Threads:
0x00000000401b0280 VMThread [id=16356]
0x00002aaaaabe02b0 WatcherThread [id=16364]
VM state:not at safepoint (normal execution)
VM Mutex/Monitor currently owned by a thread: None
Heap
def new generation total 39296K, used 6441K [0x00002af812a40000, 0x00002af8154e0000, 0x00002af81d4e0000)
eden space 34944K, 6% used [0x00002af812a40000, 0x00002af812c4c440, 0x00002af814c60000)
from space 4352K, 99% used [0x00002af8150a0000, 0x00002af8154de248, 0x00002af8154e0000)
to space 4352K, 0% used [0x00002af814c60000, 0x00002af814c60000, 0x00002af8150a0000)
tenured generation total 87424K, used 0K [0x00002af81d4e0000, 0x00002af822a40000, 0x00002af832a40000)
the space 87424K, 0% used [0x00002af81d4e0000, 0x00002af81d4e0000, 0x00002af81d4e0200, 0x00002af822a40000)
compacting perm gen total 24448K, used 24295K [0x00002af832a40000, 0x00002af834220000, 0x00002af837e40000)
the space 24448K, 99% used [0x00002af832a40000, 0x00002af8341f9ee8, 0x00002af8341fa000, 0x00002af834220000)
No shared spaces configured.
Dynamic libraries:
40000000-4000e000 r-xp 00000000 03:02 220100862 /home/alex/programs/VP_Suite3.0/jre/bin/java
4010d000-40110000 rwxp 0000d000 03:02 220100862 /home/alex/programs/VP_Suite3.0/jre/bin/java
40110000-401c3000 rwxp 40110000 00:00 0 [heap]
401c3000-401c4000 —p 401c3000 00:00 0
401c4000-402c4000 rwxp 401c4000 00:00 0
402c4000-402c7000 —p 402c4000 00:00 0
402c7000-403c5000 rwxp 402c7000 00:00 0
403c5000-403c8000 —p 403c5000 00:00 0
403c8000-404c6000 rwxp 403c8000 00:00 0
404c6000-404c9000 —p 404c6000 00:00 0
404c9000-405c7000 rwxp 404c9000 00:00 0
405c7000-405ca000 —p 405c7000 00:00 0
405ca000-406c8000 rwxp 405ca000 00:00 0
406c8000-406cb000 —p 406c8000 00:00 0
406cb000-407c9000 rwxp 406cb000 00:00 0
407c9000-407cc000 —p 407c9000 00:00 0
407cc000-408ca000 rwxp 407cc000 00:00 0
408ca000-408cd000 —p 408ca000 00:00 0
408cd000-409cb000 rwxp 408cd000 00:00 0
409cb000-409cc000 —p 409cb000 00:00 0
409cc000-40acc000 rwxp 409cc000 00:00 0
40acc000-40acf000 —p 40acc000 00:00 0
40acf000-40bcd000 rwxp 40acf000 00:00 0
40bcd000-40bd0000 —p 40bcd000 00:00 0
40bd0000-40cce000 rwxp 40bd0000 00:00 0
40cce000-40cd1000 —p 40cce000 00:00 0
40cd1000-40dcf000 rwxp 40cd1000 00:00 0
40dcf000-40dd2000 —p 40dcf000 00:00 0
40dd2000-40ed0000 rwxp 40dd2000 00:00 0
40ed0000-40ed3000 —p 40ed0000 00:00 0
40ed3000-40fd1000 rwxp 40ed3000 00:00 0
40fd1000-40fd4000 —p 40fd1000 00:00 0
40fd4000-410d2000 rwxp 40fd4000 00:00 0
410d2000-410d5000 —p 410d2000 00:00 0
410d5000-411d3000 rwxp 410d5000 00:00 0
2aaaaaaab000-2aaaaabd3000 r-xp 00000000 08:06 33607027 /usr/lib/locale/locale-archive
2aaaaabd3000-2aaaaacd3000 rwxp 2aaaaabd3000 00:00 0
2aaaaacd3000-2aaaaacfa000 r-xs 00000000 03:02 13048674 /home/alex/programs/VP_Suite3.0/jre/lib/ext/sunjce_provider.jar
2aaaaacfa000-2aaaaacfc000 r-xs 00000000 03:02 13048675 /home/alex/programs/VP_Suite3.0/jre/lib/ext/dnsns.jar
2aaaaacfc000-2aaaaadc1000 r-xs 00000000 03:02 13048676 /home/alex/programs/VP_Suite3.0/jre/lib/ext/localedata.jar
2aaaaadc1000-2aaaaae10000 r-xs 00000000 03:02 168540636 /home/alex/programs/VP_Suite3.0/.install4j/i4jruntime.jar
2aaaaae10000-2aaaae8fa000 r-xs 00000000 03:02 85385948 /home/alex/programs/VP_Suite3.0/lib/vpplatform.jar
2aaaae8fa000-2aaaaea6e000 rwxp 2aaaae8fa000 00:00 0
2aaaaea6e000-2aaaaea92000 r-xs 00000000 03:02 85385947 /home/alex/programs/VP_Suite3.0/lib/winpack.jar
2aaaaea92000-2aaaaeb2e000 r-xs 00000000 03:02 85385949 /home/alex/programs/VP_Suite3.0/lib/jniwrap.jar
2aaaaeb2e000-2aaaaebb0000 r-xs 00000000 03:02 85385946 /home/alex/programs/VP_Suite3.0/lib/jh.jar
2aaaaebb0000-2aaaaf019000 r-xs 00000000 03:02 85385952 /home/alex/programs/VP_Suite3.0/lib/xalan.jar
2aaaaf019000-2aaaaf072000 r-xs 00000000 03:02 85385950 /home/alex/programs/VP_Suite3.0/lib/lib01.jar
2aaaaf072000-2aaaaf268000 r-xs 00000000 03:02 85385951 /home/alex/programs/VP_Suite3.0/lib/lib02.jar
2aaaaf268000-2aaaaf2e7000 r-xs 00000000 03:02 85385954 /home/alex/programs/VP_Suite3.0/lib/lib03.jar
2aaaaf2e7000-2aaaaf53a000 r-xs 00000000 03:02 13044565 /home/alex/programs/VP_Suite3.0/ormlib/orm.jar
2aaaaf53a000-2aaaaf5a7000 r-xs 00000000 03:02 13044566 /home/alex/programs/VP_Suite3.0/ormlib/antlr.jar
2aaaaf5a7000-2aaaaf5ae000 r-xs 00000000 03:02 13044569 /home/alex/programs/VP_Suite3.0/ormlib/asm.jar
2aaaaf5ae000-2aaaaf6ae000 rwxp 2aaaaf5ae000 00:00 0
2aaaaf6ae000-2aaaaf6b3000 r-xs 00000000 03:02 13044575 /home/alex/programs/VP_Suite3.0/ormlib/asm-attrs.jar
2aaaaf6b3000-2aaaaf748000 r-xs 00000000 03:02 13044567 /home/alex/programs/VP_Suite3.0/ormlib/c3p0.jar
2aaaaf748000-2aaaaf78d000 r-xs 00000000 03:02 13048480 /home/alex/programs/VP_Suite3.0/ormlib/cglib.jar
2aaaaf78d000-2aaaaf7b8000 r-xs 00000000 03:02 13044574 /home/alex/programs/VP_Suite3.0/ormlib/commons-collections.jar
2aaaaf7b8000-2aaaaf7ba000 r-xs 00000000 03:02 13048482 /home/alex/programs/VP_Suite3.0/ormlib/jdbc2_0-stdext.jar
2aaaaf7ba000-2aaaaf7bd000 r-xs 00000000 03:02 13044568 /home/alex/programs/VP_Suite3.0/ormlib/jta.jar
2aaaaf7bd000-2aaaaf813000 r-xs 00000000 03:02 13044573 /home/alex/programs/VP_Suite3.0/ormlib/log4j.jar
2aaaaf813000-2aaaaf880000 r-xp 00000000 03:02 24364852 /home/alex/programs/VP_Suite3.0/jre/lib/amd64/libawt.so
2aaaaf880000-2aaaaf983000 —p 0006d000 03:02 24364852 /home/alex/programs/VP_Suite3.0/jre/lib/amd64/libawt.so
2aaaaf983000-2aaaaf997000 rwxp 00070000 03:02 24364852 /home/alex/programs/VP_Suite3.0/jre/lib/amd64/libawt.so
2aaaaf997000-2aaaaf9bb000 rwxp 2aaaaf997000 00:00 0
2aaaaf9bb000-2aaaafa65000 r-xp 00000000 03:02 24364837 /home/alex/programs/VP_Suite3.0/jre/lib/amd64/libmlib_image.so
2aaaafa65000-2aaaafb64000 —p 000aa000 03:02 24364837 /home/alex/programs/VP_Suite3.0/jre/lib/amd64/libmlib_image.so
2aaaafb64000-2aaaafb69000 rwxp 000a9000 03:02 24364837 /home/alex/programs/VP_Suite3.0/jre/lib/amd64/libmlib_image.so
2aaaafb69000-2aaaafb9b000 r-xp 00000000 03:02 37850704 /home/alex/programs/VP_Suite3.0/jre/lib/amd64/xawt/libmawt.so
2aaaafb9b000-2aaaafc9d000 —p 00032000 03:02 37850704 /home/alex/programs/VP_Suite3.0/jre/lib/amd64/xawt/libmawt.so
2aaaafc9d000-2aaaafca8000 rwxp 00034000 03:02 37850704 /home/alex/programs/VP_Suite3.0/jre/lib/amd64/xawt/libmawt.so
2aaaafca8000-2aaaafca9000 rwxp 2aaaafca8000 00:00 0
2aaaafca9000-2aaaafcaa000 r-xs 00000000 08:06 34309441 /var/cache/fontconfig/b3fedf7c409f006ca1a6fceffceb77cf-x86-64.cache-2
2aaaafcaa000-2aaaafcac000 r-xs 00000000 08:06 33818751 /var/cache/fontconfig/9404ff413c67fc2a1526fd14eb4163a8-x86-64.cache-2
2aaaafcac000-2aaaafcb6000 r-xs 00000000 08:06 34309443 /var/cache/fontconfig/a960c40fc9306f090224a04585f8a963-x86-64.cache-2
2aaaafcb6000-2aaaafcb7000 r-xs 00000000 08:06 34515977 /var/cache/fontconfig/92a571655fb1c0ec1c4d6f496220600a-x86-64.cache-2
2aaaafcb7000-2aaaafcb8000 r-xs 00000000 08:06 33818753 /var/cache/fontconfig/892f88ea27b235637f494d515247eddd-x86-64.cache-2
2aaaafcb8000-2aaaafcb9000 r-xs 00000000 08:06 34515979 /var/cache/fontconfig/e0f9e95429e756d56293ed4d63866094-x86-64.cache-2
2aaaafcb9000-2aaaafcbb000 r-xs 00000000 08:06 34515980 /var/cache/fontconfig/61c830dfac3fd78a12654da5e9ba3f56-x86-64.cache-2
2aaaafcbb000-2aaaafcbc000 r-xs 00000000 08:06 34515981 /var/cache/fontconfig/0f32d3adc6a232110812e17374eaa446-x86-64.cache-2
2aaaafcbc000-2aaaafcc0000 r-xs 00000000 08:06 34515982 /var/cache/fontconfig/8ab5f685cd6d8ba67c37c908faf08172-x86-64.cache-2
2aaaafcc0000-2aaaafcd0000 r-xp 00000000 08:06 33567819 /usr/lib/libXext.so.6.4.0
2aaaafcd0000-2aaaafdd0000 —p 00010000 08:06 33567819 /usr/lib/libXext.so.6.4.0
2aaaafdd0000-2aaaafdd1000 rwxp 00010000 08:06 33567819 /usr/lib/libXext.so.6.4.0
2aaaafdd1000-2aaaafed3000 r-xp 00000000 08:06 33554611 /usr/lib/libX11.so.6.2.0
2aaaafed3000-2aaaaffd3000 —p 00102000 08:06 33554611 /usr/lib/libX11.so.6.2.0
2aaaaffd3000-2aaaaffda000 rwxp 00102000 08:06 33554611 /usr/lib/libX11.so.6.2.0
2aaaaffda000-2aaaaffdc000 r-xp 00000000 08:06 33554586 /usr/lib/libXau.so.6.0.0
2aaaaffdc000-2aaab00db000 —p 00002000 08:06 33554586 /usr/lib/libXau.so.6.0.0
2aaab00db000-2aaab00dc000 rwxp 00001000 08:06 33554586 /usr/lib/libXau.so.6.0.0
2aaab00dc000-2aaab00e1000 r-xp 00000000 08:06 33554588 /usr/lib/libXdmcp.so.6.0.0
2aaab00e1000-2aaab01e0000 —p 00005000 08:06 33554588 /usr/lib/libXdmcp.so.6.0.0
2aaab01e0000-2aaab01e1000 rwxp 00004000 08:06 33554588 /usr/lib/libXdmcp.so.6.0.0
2aaab01e1000-2aaab05e1000 rwxp 2aaab01e1000 00:00 0
2aaab05e1000-2aaab0660000 r-xp 00000000 03:02 24364832 /home/alex/programs/VP_Suite3.0/jre/lib/amd64/libfontmanager.so
2aaab0660000-2aaab0761000 —p 0007f000 03:02 24364832 /home/alex/programs/VP_Suite3.0/jre/lib/amd64/libfontmanager.so
2aaab0761000-2aaab0777000 rwxp 00080000 03:02 24364832 /home/alex/programs/VP_Suite3.0/jre/lib/amd64/libfontmanager.so
2aaab0777000-2aaab0988000 rwxp 2aaab0777000 00:00 0
2aaab09ef000-2aaab0aef000 rwxp 2aaab09ef000 00:00 0
2aaab0aef000-2aaab0af9000 r-xp 00000000 08:06 33568229 /usr/lib/libXcursor.so.1.0.2
2aaab0af9000-2aaab0bf8000 —p 0000a000 08:06 33568229 /usr/lib/libXcursor.so.1.0.2
2aaab0bf8000-2aaab0bf9000 rwxp 00009000 08:06 33568229 /usr/lib/libXcursor.so.1.0.2
2aaab0c6c000-2aaab0c6d000 r-xs 00000000 08:06 34515983 /var/cache/fontconfig/118d8d5311348bbdf5fe3b106d7c13d4-x86-64.cache-2
2aaab0c6d000-2aaab0c6e000 r-xs 00000000 08:06 34515984 /var/cache/fontconfig/059138ec877db160474b4d5de1248d14-x86-64.cache-2
2aaab0c6e000-2aaab0c72000 r-xs 00000000 08:06 34516013 /var/cache/fontconfig/b21a91cee725896328b8cee8091cf747-x86-64.cache-2
2aaab0c72000-2aaab0c73000 r-xs 00000000 08:06 33818756 /var/cache/fontconfig/bf1f9632594a1fa28e2cf4d7888deffe-x86-64.cache-2
2aaab0c73000-2aaab0c74000 r-xs 00000000 08:06 34516015 /var/cache/fontconfig/aa6caf9eb4374966b8da29da8547f4f4-x86-64.cache-2
2aaab0c74000-2aaab0c75000 r-xs 00000000 08:06 34516027 /var/cache/fontconfig/c6c650a19da23b8ee5782aefc5f28033-x86-64.cache-2
2aaab0c75000-2aaab0cd1000 r-xs 00000000 08:06 34309421 /var/cache/fontconfig/21a99156bb11811cef641abeda519a45-x86-64.cache-2
2aaab0cd1000-2aaab0d2d000 r-xs 00000000 08:06 34309422 /var/cache/fontconfig/eeebfc908bd29a90773fd860017aada4-x86-64.cache-2
2aaab0d2d000-2aaab0d37000 r-xs 00000000 08:06 34309423 /var/cache/fontconfig/e13b20fdb08344e0e664864cc2ede53d-x86-64.cache-2
2aaab0d37000-2aaab0d4d000 r-xs 00000000 08:06 34309426 /var/cache/fontconfig/cabbd14511b9e8a55e92af97fb3a0461-x86-64.cache-2
2aaab0d4d000-2aaab0d53000 r-xs 00000000 08:06 34309429 /var/cache/fontconfig/105b9c7e6f0a4f82d8c9b6e39c52c6f9-x86-64.cache-2
2aaab0d53000-2aaab0d55000 r-xs 00000000 08:06 34309430 /var/cache/fontconfig/de9486f0b47a4d768a594cb4198cb1c6-x86-64.cache-2
2aaab0d55000-2aaab0d74000 r-xs 00000000 08:06 34309440 /var/cache/fontconfig/365b55f210c0a22e9a19e35191240f32-x86-64.cache-2
2aaab0d74000-2aaab0d75000 r-xs 00000000 08:06 34309431 /var/cache/fontconfig/4794a0821666d79190d59a36cb4f44b5-x86-64.cache-2
2aaab0d75000-2aaab0d76000 r-xs 00000000 08:06 34309432 /var/cache/fontconfig/9451a55048e8dbe8633e64d34165fdf2-x86-64.cache-2
2aaab0d76000-2aaab0d7d000 r-xs 00000000 08:06 34309433 /var/cache/fontconfig/6d41288fd70b0be22e8c3a91e032eec0-x86-64.cache-2
2aaab0d7d000-2aaab0d85000 r-xs 00000000 08:06 34309435 /var/cache/fontconfig/945677eb7aeaf62f1d50efc3fb3ec7d8-x86-64.cache-2
2aaab0d85000-2aaab0d8e000 r-xp 00000000 08:06 33567802 /usr/lib/libXrender.so.1.3.0
2aaab0d8e000-2aaab0e8d000 —p 00009000 08:06 33567802 /usr/lib/libXrender.so.1.3.0
2aaab0e8d000-2aaab0e8e000 rwxp 00008000 08:06 33567802 /usr/lib/libXrender.so.1.3.0
2aaab0e8e000-2aaab0e93000 r-xp 00000000 08:06 33567788 /usr/lib/libXfixes.so.3.1.0
2aaab0e93000-2aaab0f92000 —p 00005000 08:06 33567788 /usr/lib/libXfixes.so.3.1.0
2aaab0f92000-2aaab0f93000 rwxp 00004000 08:06 33567788 /usr/lib/libXfixes.so.3.1.0
2aaab1000000-2aaab10fd000 rwxp 2aaab1000000 00:00 0
2aaab10fd000-2aaab1100000 —p 2aaab10fd000 00:00 0
2aaab1100000-2aaab1159000 r-xp 00000000 03:02 24364853 /home/alex/programs/VP_Suite3.0/jre/lib/amd64/libcmm.so
2aaab1159000-2aaab125c000 —p 00059000 03:02 24364853 /home/alex/programs/VP_Suite3.0/jre/lib/amd64/libcmm.so
2aaab125c000-2aaab126b000 rwxp 0005c000 03:02 24364853 /home/alex/programs/VP_Suite3.0/jre/lib/amd64/libcmm.so
2aaab126b000-2aaab126c000 rwxp 2aaab126b000 00:00 0
2aaab126c000-2aaab1295000 r-xp 00000000 03:02 24364848 /home/alex/programs/VP_Suite3.0/jre/lib/amd64/libjpeg.so
2aaab1295000-2aaab1394000 —p 00029000 03:02 24364848 /home/alex/programs/VP_Suite3.0/jre/lib/amd64/libjpeg.so
2aaab1394000-2aaab139b000 rwxp 00028000 03:02 24364848 /home/alex/programs/VP_Suite3.0/jre/lib/amd64/libjpeg.so
2aaab1426000-2aaab175a000 rwxp 2aaab1426000 00:00 0
2aaab1769000-2aaab1969000 rwxp 2aaab1769000 00:00 0
2aaab19da000-2aaab1bda000 rwxp 2aaab19da000 00:00 0
2aaab1c21000-2aaab1d21000 rwxp 2aaab1c21000 00:00 0
2aaab1d2a000-2aaab222a000 rwxp 2aaab1d2a000 00:00 0
2aaab222a000-2aaab22bd000 rwxs 00000000 00:08 581140487 /SYSV00000000 (deleted)
2aaab22bd000-2aaab2350000 rwxs 00000000 00:08 581173257 /SYSV00000000 (deleted)
2aaab2350000-2aaab2362000 r-xp 00000000 03:02 24364825 /home/alex/programs/VP_Suite3.0/jre/lib/amd64/libnet.so
2aaab2362000-2aaab2464000 —p 00012000 03:02 24364825 /home/alex/programs/VP_Suite3.0/jre/lib/amd64/libnet.so
2aaab2464000-2aaab2467000 rwxp 00014000 03:02 24364825 /home/alex/programs/VP_Suite3.0/jre/lib/amd64/libnet.so
2aaab2467000-2aaab246e000 r-xp 00000000 03:02 24364826 /home/alex/programs/VP_Suite3.0/jre/lib/amd64/libnio.so
2aaab246e000-2aaab256d000 —p 00007000 03:02 24364826 /home/alex/programs/VP_Suite3.0/jre/lib/amd64/libnio.so
2aaab256d000-2aaab256f000 rwxp 00006000 03:02 24364826 /home/alex/programs/VP_Suite3.0/jre/lib/amd64/libnio.so
2aaab2a00000-2aaab2aaf000 rwxp 2aaab2a00000 00:00 0
2aaab2aaf000-2aaab2b00000 —p 2aaab2aaf000 00:00 0
2aaab2b17000-2aaab2b47000 r-xp 00000000 08:06 33554809 /usr/lib/libcups.so.2
2aaab2b47000-2aaab2c46000 —p 00030000 08:06 33554809 /usr/lib/libcups.so.2
2aaab2c46000-2aaab2c49000 rwxp 0002f000 08:06 33554809 /usr/lib/libcups.so.2
2aaab2c49000-2aaab2cbc000 r-xp 00000000 08:06 33555084 /usr/lib/libgnutls.so.13.0.9
2aaab2cbc000-2aaab2dbb000 —p 00073000 08:06 33555084 /usr/lib/libgnutls.so.13.0.9
2aaab2dbb000-2aaab2dc6000 rwxp 00072000 08:06 33555084 /usr/lib/libgnutls.so.13.0.9
2aaab2dc6000-2aaab2dcb000 r-xp 00000000 08:06 8435412 /lib/libcrypt-2.3.6.so
2aaab2dcb000-2aaab2eca000 —p 00005000 08:06 8435412 /lib/libcrypt-2.3.6.so
2aaab2eca000-2aaab2ecc000 rwxp 00004000 08:06 8435412 /lib/libcrypt-2.3.6.so
2aaab2ecc000-2aaab2efa000 rwxp 2aaab2ecc000 00:00 0
2aaab2efa000-2aaab2f10000 r-xp 00000000 08:06 33554798 /usr/lib/libz.so.1.2.3
2aaab2f10000-2aaab300f000 —p 00016000 08:06 33554798 /usr/lib/libz.so.1.2.3
2aaab300f000-2aaab3010000 rwxp 00015000 08:06 33554798 /usr/lib/libz.so.1.2.3
2aaab3010000-2aaab3024000 r-xp 00000000 08:06 33574542 /usr/lib/libtasn1.so.3.0.6
2aaab3024000-2aaab3123000 —p 00014000 08:06 33574542 /usr/lib/libtasn1.so.3.0.6
2aaab3123000-2aaab3124000 rwxp 00013000 08:06 33574542 /usr/lib/libtasn1.so.3.0.6
2aaab3124000-2aaab316e000 r-xp 00000000 08:06 33573617 /usr/lib/libgcrypt.so.11.2.2
2aaab316e000-2aaab326d000 —p 0004a000 08:06 33573617 /usr/lib/libgcrypt.so.11.2.2
2aaab326d000-2aaab3270000 rwxp 00049000 08:06 33573617 /usr/lib/libgcrypt.so.11.2.2
2aaab3270000-2aaab3273000 r-xp 00000000 08:06 33573629 /usr/lib/libgpg-error.so.0.3.0
2aaab3273000-2aaab3372000 —p 00003000 08:06 33573629 /usr/lib/libgpg-error.so.0.3.0
2aaab3372000-2aaab3373000 rwxp 00002000 08:06 33573629 /usr/lib/libgpg-error.so.0.3.0
2aaab3373000-2aaab3378000 r-xp 00000000 08:06 33651054 /usr/lib/libnss_db-2.2.3.so
2aaab3378000-2aaab3478000 —p 00005000 08:06 33651054 /usr/lib/libnss_db-2.2.3.so
2aaab3478000-2aaab3479000 rwxp 00005000 08:06 33651054 /usr/lib/libnss_db-2.2.3.so
2aaab3479000-2aaab3565000 r-xp 00000000 08:06 33555108 /usr/lib/libdb-4.3.so
2aaab3565000-2aaab3665000 —p 000ec000 08:06 33555108 /usr/lib/libdb-4.3.so
2aaab3665000-2aaab366a000 rwxp 000ec000 08:06 33555108 /usr/lib/libdb-4.3.so
2aaab366a000-2aaab366c000 r-xp 00000000 08:06 8434370 /lib/libnss_mdns4_minimal.so.2
2aaab366c000-2aaab376b000 —p 00002000 08:06 8434370 /lib/libnss_mdns4_minimal.so.2
2aaab376b000-2aaab376c000 rwxp 00001000 08:06 8434370 /lib/libnss_mdns4_minimal.so.2
2aaab376c000-2aaab3770000 r-xp 00000000 08:06 8522245 /lib/libnss_dns-2.3.6.so
2aaab3770000-2aaab3870000 —p 00004000 08:06 8522245 /lib/libnss_dns-2.3.6.so
2aaab3870000-2aaab3872000 rwxp 00004000 08:06 8522245 /lib/libnss_dns-2.3.6.so
2aaab3872000-2aaab3883000 r-xp 00000000 08:06 8522246 /lib/libresolv-2.3.6.so
2aaab3883000-2aaab3983000 —p 00011000 08:06 8522246 /lib/libresolv-2.3.6.so
2aaab3983000-2aaab3985000 rwxp 00011000 08:06 8522246 /lib/libresolv-2.3.6.so
2aaab3985000-2aaab3987000 rwxp 2aaab3985000 00:00 0
2aaab3987000-2aaab3989000 r-xp 00000000 08:06 8735778 /lib/libnss_mdns4.so.2
2aaab3989000-2aaab3a88000 —p 00002000 08:06 8735778 /lib/libnss_mdns4.so.2
2aaab3a88000-2aaab3a89000 rwxp 00001000 08:06 8735778 /lib/libnss_mdns4.so.2
2af80b0cd000-2af80b0e4000 r-xp 00000000 08:06 8522238 /lib/ld-2.3.6.so
2af80b0e4000-2af80b0e6000 rwxp 2af80b0e4000 00:00 0
2af80b1e3000-2af80b1e5000 rwxp 00016000 08:06 8522238 /lib/ld-2.3.6.so
2af80b1e5000-2af80b1f5000 r-xp 00000000 08:06 8522247 /lib/libpthread-2.3.6.so
2af80b1f5000-2af80b2f4000 —p 00010000 08:06 8522247 /lib/libpthread-2.3.6.so
2af80b2f4000-2af80b2f6000 rwxp 0000f000 08:06 8522247 /lib/libpthread-2.3.6.so
2af80b2f6000-2af80b2fa000 rwxp 2af80b2f6000 00:00 0
2af80b2fa000-2af80b2fc000 r-xp 00000000 08:06 8435415 /lib/libdl-2.3.6.so
2af80b2fc000-2af80b3fb000 —p 00002000 08:06 8435415 /lib/libdl-2.3.6.so
2af80b3fb000-2af80b3fd000 rwxp 00001000 08:06 8435415 /lib/libdl-2.3.6.so
2af80b3fd000-2af80b3fe000 rwxp 2af80b3fd000 00:00 0
2af80b3fe000-2af80b51f000 r-xp 00000000 08:06 8435414 /lib/libc-2.3.6.so
2af80b51f000-2af80b61f000 —p 00121000 08:06 8435414 /lib/libc-2.3.6.so
2af80b61f000-2af80b634000 r-xp 00121000 08:06 8435414 /lib/libc-2.3.6.so
2af80b634000-2af80b637000 rwxp 00136000 08:06 8435414 /lib/libc-2.3.6.so
2af80b637000-2af80b63c000 rwxp 2af80b637000 00:00 0
2af80b63c000-2af80bd08000 r-xp 00000000 03:02 85390548 /home/alex/programs/VP_Suite3.0/jre/lib/amd64/server/libjvm.so
2af80bd08000-2af80be08000 —p 006cc000 03:02 85390548 /home/alex/programs/VP_Suite3.0/jre/lib/amd64/server/libjvm.so
2af80be08000-2af80bf83000 rwxp 006cc000 03:02 85390548 /home/alex/programs/VP_Suite3.0/jre/lib/amd64/server/libjvm.so
2af80bf83000-2af80bfb2000 rwxp 2af80bf83000 00:00 0
2af80bfb2000-2af80bfb3000 r-xp 2af80bfb2000 00:00 0
2af80bfb3000-2af80bfb4000 rwxp 2af80bfb3000 00:00 0
2af80bfc9000-2af80c04a000 r-xp 00000000 08:06 8435416 /lib/libm-2.3.6.so
2af80c04a000-2af80c149000 —p 00081000 08:06 8435416 /lib/libm-2.3.6.so
2af80c149000-2af80c14b000 rwxp 00080000 08:06 8435416 /lib/libm-2.3.6.so
2af80c14b000-2af80c154000 r-xp 00000000 03:02 51421822 /home/alex/programs/VP_Suite3.0/jre/lib/amd64/native_threads/libhpi.so
2af80c154000-2af80c253000 —p 00009000 03:02 51421822 /home/alex/programs/VP_Suite3.0/jre/lib/amd64/native_threads/libhpi.so
2af80c253000-2af80c257000 rwxp 00008000 03:02 51421822 /home/alex/programs/VP_Suite3.0/jre/lib/amd64/native_threads/libhpi.so
2af80c257000-2af80c25f000 rwxs 00000000 08:06 75921499 /tmp/hsperfdata_alex/16349
2af80c26e000-2af80c282000 r-xp 00000000 08:06 8522243 /lib/libnsl-2.3.6.so
2af80c282000-2af80c381000 —p 00014000 08:06 8522243 /lib/libnsl-2.3.6.so
2af80c381000-2af80c383000 rwxp 00013000 08:06 8522243 /lib/libnsl-2.3.6.so
2af80c383000-2af80c385000 rwxp 2af80c383000 00:00 0
2af80c385000-2af80c38c000 r-xp 00000000 08:06 8522240 /lib/libnss_compat-2.3.6.so
2af80c38c000-2af80c48c000 —p 00007000 08:06 8522240 /lib/libnss_compat-2.3.6.so
2af80c48c000-2af80c48e000 rwxp 00007000 08:06 8522240 /lib/libnss_compat-2.3.6.so
2af80c48e000-2af80c497000 r-xp 00000000 08:06 8435411 /lib/libnss_nis-2.3.6.so
2af80c497000-2af80c597000 —p 00009000 08:06 8435411 /lib/libnss_nis-2.3.6.so
2af80c597000-2af80c599000 rwxp 00009000 08:06 8435411 /lib/libnss_nis-2.3.6.so
2af80c599000-2af80c5a3000 r-xp 00000000 08:06 8435418 /lib/libnss_files-2.3.6.so
2af80c5a3000-2af80c6a2000 —p 0000a000 08:06 8435418 /lib/libnss_files-2.3.6.so
2af80c6a2000-2af80c6a4000 rwxp 00009000 08:06 8435418 /lib/libnss_files-2.3.6.so
2af80c6a4000-2af80c6b1000 r-xp 00000000 03:02 24364828 /home/alex/programs/VP_Suite3.0/jre/lib/amd64/libverify.so
2af80c6b1000-2af80c7b0000 —p 0000d000 03:02 24364828 /home/alex/programs/VP_Suite3.0/jre/lib/amd64/libverify.so
2af80c7b0000-2af80c7b3000 rwxp 0000c000 03:02 24364828 /home/alex/programs/VP_Suite3.0/jre/lib/amd64/libverify.so
2af80c7b3000-2af80c7d8000 r-xp 00000000 03:02 24364841 /home/alex/programs/VP_Suite3.0/jre/lib/amd64/libjava.so
2af80c7d8000-2af80c8d7000 —p 00025000 03:02 24364841 /home/alex/programs/VP_Suite3.0/jre/lib/amd64/libjava.so
2af80c8d7000-2af80c8dd000 rwxp 00024000 03:02 24364841 /home/alex/programs/VP_Suite3.0/jre/lib/amd64/libjava.so
2af80c8dd000-2af80c8ec000 r-xp 00000000 03:02 24364834 /home/alex/programs/VP_Suite3.0/jre/lib/amd64/libzip.so
2af80c8ec000-2af80c9ed000 —p 0000f000 03:02 24364834 /home/alex/programs/VP_Suite3.0/jre/lib/amd64/libzip.so
2af80c9ed000-2af80c9f1000 rwxp 00010000 03:02 24364834 /home/alex/programs/VP_Suite3.0/jre/lib/amd64/libzip.so
2af80c9f1000-2af80efff000 r-xs 00000000 03:02 236780691 /home/alex/programs/VP_Suite3.0/jre/lib/rt.jar
2af80efff000-2af80f068000 rwxp 2af80efff000 00:00 0
2af80f068000-2af80f0ed000 r-xs 00000000 03:02 236806957 /home/alex/programs/VP_Suite3.0/jre/lib/jsse.jar
2af80f0ed000-2af80f102000 r-xs 00000000 03:02 236806958 /home/alex/programs/VP_Suite3.0/jre/lib/jce.jar
2af80f102000-2af80f971000 r-xs 00000000 03:02 236806959 /home/alex/programs/VP_Suite3.0/jre/lib/charsets.jar
2af80f971000-2af80fbe1000 rwxp 2af80f971000 00:00 0
2af80fbe1000-2af812971000 rwxp 2af80fbe1000 00:00 0
2af812971000-2af81297b000 rwxp 2af812971000 00:00 0
2af81297b000-2af812a31000 rwxp 2af81297b000 00:00 0
2af812a40000-2af8154e0000 rwxp 2af812a40000 00:00 0
2af8154e0000-2af81d4e0000 rwxp 2af8154e0000 00:00 0
2af81d4e0000-2af822a40000 rwxp 2af81d4e0000 00:00 0
2af822a40000-2af832a40000 rwxp 2af822a40000 00:00 0
2af832a40000-2af834220000 rwxp 2af832a40000 00:00 0
2af834220000-2af837e40000 rwxp 2af834220000 00:00 0
2af837e40000-2af837e56000 rwxp 2af837e40000 00:00 0
2af837e56000-2af837e95000 rwxp 2af837e56000 00:00 0
2af837e95000-2af837ec0000 rwxp 2af837e95000 00:00 0
2af837ec0000-2af837f40000 rwxp 2af837ec0000 00:00 0
2af837f40000-2af837f4c000 rwxp 2af837f40000 00:00 0
2af837f4c000-2af837f6a000 rwxp 2af837f4c000 00:00 0
2af837f6a000-2af837f96000 rwxp 2af837f6a000 00:00 0
2af837f96000-2af838016000 rwxp 2af837f96000 00:00 0
2af838016000-2af838022000 rwxp 2af838016000 00:00 0
2af838022000-2af838041000 rwxp 2af838022000 00:00 0
2af838041000-2af838069000 rwxp 2af838041000 00:00 0
7fff9f7dd000-7fff9f7e0000 —p 7fff9f7dd000 00:00 0
7fff9f7e0000-7fff9f9dd000 rwxp 7fff9f7e0000 00:00 0 [stack]
ffffffffff600000-ffffffffffe00000 —p 00000000 00:00 0 [vdso]
VM Arguments:
jvm_args: -Xmx512m -Xms128m -Dsun.java2d.noddraw=true -Dswing.useSystemFontSettings=true
java_command: RV German notAskWorkspace
Launcher Type: SUN_STANDARD
Environment Variables:
PATH=/usr/local/bin:/usr/bin:/bin:/usr/games
LD_LIBRARY_PATH=/home/alex/programs/VP_Suite3.0/jre/lib/amd64/server:/home/alex/programs/VP_Suite3.0/jre/lib/amd64:/home/alex/programs/VP_Suite3.0/jre/…/lib/amd64
SHELL=/bin/bash
DISPLAY=:0.0
Signal Handlers:
SIGSEGV: [libjvm.so+0x657140], sa_mask[0]=0x7ffbfeff, sa_flags=0x14000004
SIGBUS: [libjvm.so+0x657140], sa_mask[0]=0x7ffbfeff, sa_flags=0x14000004
SIGFPE: [libjvm.so+0x55e980], sa_mask[0]=0x7ffbfeff, sa_flags=0x14000004
SIGPIPE: SIG_IGN, sa_mask[0]=0x00000000, sa_flags=0x04000000
SIGILL: [libjvm.so+0x55e980], sa_mask[0]=0x7ffbfeff, sa_flags=0x14000004
SIGUSR1: SIG_DFL, sa_mask[0]=0x00000000, sa_flags=0x00000000
SIGUSR2: [libjvm.so+0x560830], sa_mask[0]=0x00000004, sa_flags=0x14000004
SIGHUP: [libjvm.so+0x560300], sa_mask[0]=0x7ffbfeff, sa_flags=0x14000004
SIGINT: [libjvm.so+0x560300], sa_mask[0]=0x7ffbfeff, sa_flags=0x14000004
SIGQUIT: [libjvm.so+0x560300], sa_mask[0]=0x7ffbfeff, sa_flags=0x14000004
SIGTERM: [libjvm.so+0x560300], sa_mask[0]=0x7ffbfeff, sa_flags=0x14000004
--------------- S Y S T E M ---------------
OS:4.0
uname:Linux 2.6.18-4-amd64 #1 SMP Fri May 4 00:37:33 UTC 2007 x86_64
libc:glibc 2.3.6 NPTL 2.3.6
rlimit: STACK 8192k, CORE 0k, NPROC infinity, NOFILE 1024, AS infinity
load average:1.63 0.71 0.54
CPU:total 1 amd64 3dnow
Memory: 4k page, physical 2061468k(15392k free), swap 4883720k(4883576k free)
vm_info: Java HotSpot™ 64-Bit Server VM (1.5.0_10-b03) for linux-amd64, built on Nov 9 2006 12:35:08 by java_re with gcc 3.2.2 (SuSE Linux)
best regards,
alex
