It would be cool, if you add the possibility to enter more rows in interface name. With combination ctrl+enter, like in notes etc.
Why this is needed, for example I have class that has two or more provided interfaces, and/or two or more required interfaces, because some of them are added to same port, so they will be used by one class, then there is no need to create provided/required interface for each interface, their name can be separated by comma.
Restart the application
Note:
A newer release of VP Suite is now ready. If you are still using the patch I sent you, please run the product updater to advance to the latest release. In fact, you are suggested to do so because you are using a patch. Please feel free to let me know if there are any questions.
