Hi, just curious if it is possible to have the component names doing some nifty word wrapping when they become too long to fit in the box.
Currently the name is truncated so you miss out on interesting bits.
User guide shows all the examples with word-wrap in components but I’m not be able to draw in the same way.
You are right. And for your information, you can set to use ‘Enter’ instead of ‘Ctrl-Enter’ for creating a new line, if you feel more comfortable. This can be set from the Options dialog box.
All BPMN shapes! Events, tasks, gateways, data objects…
For tasks, the text should wrap within the limits of the symbol. The symbol should also auto-grow (in height, not in width!) to fit text if the later is to big to fit in the original size of the symbol.
For the other symbols where the caption is below the symbol, the text should also be limited reasonably in width, but quite longer that the symbol’s width because those symbols tends to be small. By reasonnably, I guess that would mean 200% the width of the symbol…
