I installed SDE Community Edition on WSAD 5.1 however when I click Open UML Model it gives the error below:
Your Java Runtime Environment version is not able to run Smart Development Environment Community Edition for Eclipse (Smart Development Environment Community Edition for Eclipse should run on JRE 1.4.2 or above version)
If you can suggest me what to do about it I will be glad.
Hicran.
Thanks Martyn,
That made it work. The only problem in those installation steps, second step asks to decompress the “No Install” file in WSAD home directory. I had to decompress it to eclipse home directory. I could make it work a little but still reverse engineering doesnt work. The “Update UML Model” option is always gray.
Hicran.
I am having a somewhat similar problem. I installed SDE community edition on WSAD 5.1, or I have tried. The installer never asked for the location of WASD. So I tried the no_install.zip route. Now, I get the menu option to Open a UML diagram, but when I select that, I get “The chosen operation is not currently available.” message.
