I am trying to use the VP-UML plug-in in WSAD 5.1.1 and am getting the following error:
“Your Java Runtime Environment version is not able to run Visual Paradigm for UML Professional Edition(Visual Paradigm for UML Professional Edition should run on JRE 1.4.2 or above version)”
From other threads on the forum I see that there is a “No Install” option for SDE - is there a similar option for VP-UML? If so, where can I find the noinstall.zip file?
