I’ve noticed by searching in the forums that there is a reference to a command line utility that can be used to export models in an XMI format.
- Is this the same as the xml export format from the UI ?
- If not, where can I get this utility?
Thanks!
Thanks!
Hi errant01,
Are you asking about XMI or XML? In fact we support both of them. The format is the same as the one exported from UI.
Yes, was asking about XMI this time. Thanks!
Also, is there a way to name the xml file exported from the UI as something other than “project.xml” ? I haven’t found a way to do that.
Hello errant01,
The file name is fixed.
