Hello, I am using the VP-UML Enterprise Edition with an evaluation key. I have UML projects within Select Architect repositories (http://www.selectbs.com/products/select-solution-factory.htm) which I would like to import into VP-UML. Select Architect exports both in XMI 1.1 and XMI 2.1 formats.
XMI 1.1 import: Although the VP-UML help says that this XMI version is NOT supported, the import works. (This is of course not a complaint!)
XMI 2.1 import: The help says that this version is supported, but the import does nothing except giving the message
[error 12:02:40]XMI file is not supported, xmi-version: 2.1, exporter: not found, exporter-version: not found
Any hints on the XMI 2.1 problem are appreciated.
TIA, Klaus
