I want export a diagram as XML with the command prompt. Export with cmd works but only with the traditional XML structure.
I’d like to inquire whether it is possible to choose “Simple XML Structure” as it is possible if I do the export manually?
I have the same problem…
I need to export a diagram in XML format with the command prompt.
Isn’t there any parameter implemented to choose between “Simple XML Structure” and “Traditional XML Structure” ???
This problem had been fixed and please update the software to latest patch (see the link below) to get the fix. After apply the patch you will have an extra property to control the XML should be simple or traditional format.
