I am attempting to import XSD or XML files into the Database Modeling area.
It appears to run, but I am always getting back Zero Results on the load screen.
Has anyone run into this? Any suggestions?
Regards,
Jerry
Regards,
Jerry
Hi Jerry Villano,
Thanks for your post. Your XML file needs to follow our schema in order to import the models. Our XML schema can be found in:
VPSuite/bundled/project.xsd
For XSD schemas, you can reverse it by Instant Reverse (available in VP-UML/SDE Standard Edition or above). More details about Instant Reverse for XSD can be found from the following link:
http://content.europe.visual-paradigm.com/media/documents/vpuml61ug1/html/Chapter_9_Instant_Reverse/Chapter_9_Instant_Reverse.html#toc-0-5
As you mentioned Database Modeling, you can reverse Hibernate mapping XML file at Tools > Object-Relational Mapping (ORM) > Reverse Hibernate. You can get details of this feature at the link below:
http://content.europe.visual-paradigm.com/media/documents/vpuml60ug2/html/Chapter_13_Object_Model/Chapter_13_Object_Model.html#toc-0-1-10
If there are any further inquiry, please feel free to ask.
