I’m trying to install the CE of VP for UML (VP_Suite_Windows_2_3_sp3_20061111.exe) on my WinXP Pro machine.
Unfortunately the installation fails
I get a [java.util.zip.ZipException: oversubscribed dynamic bit lengths tree] exception during the installation of vpplatform.jar
System properties (partial info of the error log file):
java.runtime.name=Java™ 2 Runtime Environment, Standard Edition
exe4j.moduleName=d:\swpool\uml\visual~1\2006-v~1.3\vp_sui~1.exe
exe4j.semaphoreName=d:_swpool_uml_visual~1_2006-v~1.3_vp_sui~1.exe
sun.boot.library.path=c:\docume~1\admini~1\locals~1\temp\e4j31.tmp_dir19475\jre\bin
java.vm.version=1.5.0_06-b05
java.vm.vendor=Sun Microsystems Inc.
Any idea what the problem is ?
What is the required/supported Java VM version ?
The complete error log file can be found in the attachment.
I am sorry about this. We are checking the problem. Could you try the No-Install version first? You can download the No-Install version from our download page as well.
I downloaded the no-install zip file and it inflated all files without problems, including the vpplatform.jar which caused the java.util.zip.ZipException.
In the meantime I installed the most recent release of J2SE, but this does not resolve the exception.
Please let me know what to do next (I find a VP Suite.exe under the bin directory but did not yet launch it).
Thank you for your reply. Please run the VP Suite.exe in the $vp-suite-install-folder/bin folder to install the product that you want to use. After the installation has been completed, you can start the application by running the launcher files under $vp-suite-install-folder/launcher
