I’ve added multiple possible source folders for my Java project, and no operations are listed for any of the contained classes. My project has an OSGI hierarchy instead of just putting every class into /src. Could that be the issue?
A sequence diagram is mostly build upon classes interacting with each other. So if that doesn’t happen in your setup then this could be a reason why the import doesn’t work. It’s a bit hard to tell without seeing the actual source code.
Please select root source folder.
I think you have package “org.lorainelab…”, so please select folder:
/home/jenny/Loraine Lab/integrated-genome-browser/core/quickload/src/main/java
