On MacOS 12.0.1, VP consumes and gets stuck after a few minutes of use.
I increased the memory setting but nothing changed.
The previous version was working well.
Here the version I use:
VP Modeler
Version 16.3 (Build 20211215)
Would you please try follow the article below to collect VP’s JVM thread dump and send us for checking? You can send it support@visual-paradigm.com in case you don’t want to upload it to forum. Thanks and look forward to hearing from you.
I did some tests and it appears that if I cut the network off (Wifi off), VP works well. There is no more CPU overloads nor application hang up.
Maybe this can help you to figure out what’s going on.
According to our engineers this problem should already fixed in our latest build 20220101. Please update the software to latest build to get it fixed. You can run the Visual Paradigm Update under Help menu to perform software update. Feel free to contact us for any help.
The installation package you’ve mentioned doesn’t start on my Mac (macos 12.0.1).
But, I downloaded VP 16.2 and updated it using the update feature.
I will instensively use VP the upcoming days. Keep you informed.
./JavaApplicationStub
Error occurred during initialization of VM
Could not find agent library jdwp on the library path, with error: dlopen(libjdwp.dylib, 0x0001): tried: '/Volumes/Visual Paradigm/Visual Paradigm.app/Contents/Resources/jre.bundle/Contents/Home/lib/server/./libjdwp.dylib' (no such file), '/Volumes/Visual Paradigm/Visual Paradigm.app/Contents/Resources/jre.bundle/Contents/Home/lib/server/../libjdwp.dylib' (no such file), 'libjdwp.dylib' (no such file), '/usr/local/lib/libjdwp.dylib' (no such file), '/usr/lib/libjdwp.dylib' (no such file), '/Volumes/Visual Paradigm/Visual Paradigm.app/Contents/Resources/app/bin/libjdwp.dylib' (no such file), '/usr/local/lib/libjdwp.dylib' (no such file), '/usr/lib/libjdwp.dylib' (no such file)
Here the content of the folder:
drwxrwxr-x 5 sto staff 170 Jan 10 12:21 .
drwxrwxr-x 59 sto staff 2006 Jan 10 12:21 ..
-rw-rw-r-- 1 sto staff 1322 Jan 10 12:21 Xusage.txt
-rw-rw-r-- 1 sto staff 50096 Jan 10 12:21 libjsig.dylib
-rw-rw-r-- 1 sto staff 14359264 Jan 10 12:21 libjvm.dylib
